Question about Bemis 4D7-800 Humidifier
Motor replacement My motor stops running and gets hot. I oil it and turn the blade and it will run for a few hours and stops again. I assume I need to replace the motor. Any idea on the part number for the motor replacement?
  • tonylou Jan 21, 2008
    I did get a motor from Grainger that was somewhat similar, the shaft was shorter but the fan stayed on but not screwed in. So far, it stayed on. Thanks
  • buckdavet Jan 08, 2009
    Can I buy a replacement motor, Bemis Part Number 5560600, direct from Bemis?
  • 625 Answers
Probably a fractional horsepower open frame motor - go to grainger dot com and see if you can find a replacement
Posted on Jan 20, 2008
My bcm740b humidifier fan isn't moving. Advice
Your problem is that your fan motor needs to be lubed. The bottom bearing on the motor can be lubed by taking the fan tower off the base and turning it upside down. Using a flashlight, you should be able to see the "bottom" bearing of the fan motor. I usually just put a drop or two of Mobil 1 or some other synthetic motor oil on the bearing and let it sit inverted for a few minutes so the oil flows into the bearing. If you are lucky, this will be sufficient and your fan motor will start running again....If not, then the "top" bearing ( when sitting in a normal position) right under the fan blade will also need to be lubed...This will require disassembly of the fan tower so you can access the bearing with some spray lube, then reassembly of the tower which can be tricky so you don't break any connectors that keep the whole assembly together. Try the bottom bearing first and save the other one for the summer!
Jan 01, 2018 | Humidifiers
Only one fan working
There are two causes of your problems:
1. The fan needs you to manually turn it to start running.
Problem: The motor bearings both ends are dried out.
1. Remove the motor/fan from the motor housing (there are two screws that hold the motor to the housing. The only way I know how to get to the screw is to bend one of the fan blade up and use a long screw driver to get to the screws.
2. Remove the two screws that hold the bearings to the motor.
3. Detach the bottom bearing (opposite of the fan end.) You might have to use a flat screw driver to pry the bearing off.
4. Use a Q-tip and soak it with motor oil or grease then lubri- cate the fan end shaft/bearing.
5. Use a Q-tip + alcohol to clean up the bottom bearing hole, then lubricate it with grease or motor oil.
6. Put the motor and bearings back together and make sure that the fan can turn freely now.
7. Install the motor/fan back into it housing.
The fan should turn on its own without you helping it.
If the fan won't turn, you have a bigger problem. See below.
2. The fan won't turn at all and is really tight even when you try to
turn it by hand.
Problem: The transformer coil(s) is/are burnt out. Chances are you let the fan run dry to a point that it squealed and started to smell like it was burning before it quit all together.
Solution 1:
1. Remove the filters and their housing on the bad fan side.
2. Duct tape a piece of plastic over the bad fan opening.
3. Run the humidifier with one fan. It works just as well.
Solution 2:
1. Buy a new humidifier.
2. Make sure you lubricate the bearings as soon as the motor begins to squeal.
Solution 3: You need knowledge of electricity
1. Take the motor/fan out from the housing.
2. Use a vote meter to check the resistance in both coil of the transformer; should read about 17 ohms. The coil(s) that has a high reading or if the meter shows 'OL' is bad. Remove the Yellow tape from the coil to see if you have a loose soldering joint between the coil wiring the electrical cord. If yes, solder the joint back together, check the resistance again to make sure you have about 17 ohms. If the answer is yes, put the yellow tape back on the coil and use electrical tape to secure the tape. Hopefully, the fan should work now. Good luck!
Feb 03, 2013 | Kenmore 14417 Humidifier
Kenmore Humidifier 14114 - the fan suddenly stopped running. Changed fliter and water, unplugged the unit, changed dial to highest humidity level - the unit will not run.
Please turn off the power to the unit and unplug it. Now check the fuse inside the unit, make sure its fine and not burnt If fuse seems OK then inspect the connections to the fan and make sure the wires are not cut. Also, inspect the control for any burnt components, use a multimeter to confirm. Hope this helps... Please post back with complete model# if you need more information.
Jan 04, 2011 | Kenmore Humidifiers
When I turn on the unit, it humms and the fan doesn't turn. Help.
If you can easily get to motor I would unplug unit and check motor to see if it turns freely. If it does I would plug the unit back in and see if the humming noise is coming from motor. Ifyou decide that the motor is the source of the noise and you can do so safely spin the fan and see if it will try to run, If it does I would unplug unit and give fan motor and blades a thorough cleaning. Clean any hair,lint or dust from aaround motor shaft. A small motor like these does not take much to slow or stop them. Plug it back in and try it. If it stiil does not work I would replace the motor. Hope this helps. Thanks
Nov 19, 2010 | Bemis 697 400 Humidifier
Am repairing this a/c split unit .whirlpool As-12cr3fd initially the evaporator motor was not starting up, the cap was changed and only when the rpm sensor jack was unplug the motor would spin. the...
sounds like 1 of a few issues here. Either the run capacitor is incorrectly sized with a capacitor that is too large. The motor may also be receiving the incorrect voltage. Or the motor may not have been oiled as needed and now the bearings are heating up and overheating...and possibly swelling up and slowing the motor down, which will affect any sensor hooked into is as this will cause a dramatic increase in amp draw to get the motor to run as designed.
Best bet at this point is to replace the motor and capacitor. Make sure the fan blades are clean and free of obstruction.
May 19, 2010 | Humidifiers
My aprilair's humidifier motor began to make loud squealing noise
Put some lubricant, oil, WD40, etc. on shaft of fan. Spin the fan with your finger and work the oil into the shaft until the fan spins freely again. Reassemble and problem will be gone for 2-3 weeks. Repeat again until you want to replace the fan motor.
Dec 31, 2009 | Aprilaire 700 Humidifier
General Aire 1137 Humidifier fan won't engage.
the lubracation used in the fan motor has an expected life of 5 years... once the lub is gone from the oillite bearings then the fan will stop .. you can put a couple of drops of oil on the motor bearings if you can get to them .. spin it by hand a few times to distribute the oil ... dont use WD40 or Teflon filled Oil .. use a light non gumming machine oil .. since you cant get that oil to permiate the porous bearings (done in a vacuum) then you will have to relube every year or so to keep it going .. you could replace the motor but that might not save much over a new unit .
Dec 23, 2009 | Humidifiers
Humidifier fan blades stopped turning
Sounds like the brush is completely gone. You might be able to replace just the brush.
Good luck.
Apr 11, 2017 | Duracraft DCM200 2 Gallon Humidifier
Sounds like your motor bearings are going bad. If at all possible lubricate the motor bearings using a few drops of a NON detergent oil. If the motor has sealed bearings with no oil ports then you should replace the blower motor.
Good luck
Mar 29, 2009 | Essick Air 447 302 Console Whole House...
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
Bemis 4D7-800 Humidifier Logo
315 people viewed this question
Top Bemis Humidifiers Experts
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
