Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
Playback Problem My handycam seems to record and play normally but at times (getting way too often now) the tape doesn't play. The time signature shows --/--/-- (like when the tape is empty). The entire tape seems empty. Then later sometime (random) it begins to play but the tape gets gray stripes(each about 1/10 of the screen height) horizontally. Many tapes have got spoil in a similar way, but guess what even they play normally sometimes. It's very irritating since it always seems to go bad when need. Please help!!
  • cadiche Mar 25, 2008
    I have exactly the same problem. When recording, it's perfect, but after rewinding (and I hear the tape rewinding and playing), the playback gives nothing but a blue screen, and the timer is --/--/-- - I would love a solution for this!
    Master:
  • 619 Answers
Hi , video head are need to clean , try ask video store if they have video head cleaner .
Posted on Jan 24, 2008
How to play tapes not recorded by Sony Handycam DCR-TRV130 Digital-8 Digital Camcorder
It is my understanding that the camera won't playback those formats, timecode or not. There are VCR type units for the HI8 and other formats. They should be cheap on eBay now...
Nov 18, 2012 | Sony Handycam DCR-TRV130 Digital Camcorder
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
Camcorder jittery image
How many times did you clean the head? and what with? often you can irrepairably damage the head on these machines by overcleaning. How much difference did the head cleaning make? What was "bad" about the bad tape? was it old/got wet/left in sun/etc....? Are you sure none of the missing screws are still in the machine? Are you getting the same results if you play back using a different camera/player or have you only tried your camera? Are there any unusual noises when the camera is recording or playing back? - listen really really carefully, in case there is a motor or gearing problem. Waiting for your info :)
Jul 20, 2007 | Sony Handycam CCD-TRV43 Camcorder
Static on playback
When's the last time you cleaned the recorder?
Nov 11, 2011 | Maxell GX-MP120 (4 pack) 8mm Tape
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony handy cam
If your Sony tells you it is recording yet on playback there is nothing there other than a blank screen, I had this problem and this is how I solved it.
1. Clean the heads two or three times with head cleaning kit
2. Leave the tape door open, with tape out or in, and warm the camera up for about 2 hours minimum.
3. Put in a previously recorded tape and see if it will display that film. If not, repeat 1 and 2. Persevere.
4. Once Stage 3 works (you might have a few "dirty" lines on it for a few seconds, and it is playing normally, try recording.
This worked for me. The heads were dirty and the camera cold but I persevered and thankfully it is OK (but for how long?)
Hope this helps. It seems to be rooted around dirty heads and coldness.
Jan 03, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
94 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
