Question about Sony KLV-S23A10 23 in. LCD HDTV
WHEN I FIRST TURN ON TV ALL I GET IS VERTICAL LINES FOR ABOUT 20 MIN. TO A HALF HOUR... THEN I HAVE A CLEAR PICTURE.
  • JOSEPH VADALA Dec 11, 2009
    YES THATS CORRECT SONY LCD KLV-S23A10
  • nick May 11, 2010
    what is the make, model and type. meaning plasma, lcd or led.. size etc. sounds like a heat related issue.. once its warmed up its fine correct?
    Problem Solver:
  • 11 Answers
This may be a problem on the 5 volt line in the set, there is a constant 5 volts running through it even when it is off....so long as its plugged in.
There may be condensors that are open on the 5 volt line.. after they warm up they start to function more proper. but being that they are leaky..they are no longer doing thier job of keeping voltage steady until they warm up.
i do not condone this but if you were to open it up , im willing to bet you have a series of swollen or blown condensors that are not doing thier job on the pwb (power supply board) if thats the case its a 30 minute fix for a technician. Id like to discuss this with you further , i do have a couple questions that may help me diagnose this.
Posted on Dec 11, 2009
  • nick Dec 11, 2009
    seeing as this is an lcd television. this could be a t-con ('t' connector) problem, this acts much like swollen condensors.. its related to heat. once it warms up..it will start to function proper. the t-con sits usually under a metal plate towards the top of the set. its a small modual that has one or two strap cables attached to its bottom side and one big plug that goes right to the screen on the top. for smaller televisions the price on them is not so bad. i may even have one for this particular set in my shop here but..im probably far from you. get back to me.
How may I fix colorful vertical lines on screen but clear voice on Sharp Aquos TV when I first turn it on?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 13, 2015 | Sharp Aquos Televison & Video
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Apr 04, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Jul 04, 2009 | Televison & Video
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
Apr 28, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Sony KLV-S23A10 23 in. LCD HDTV Logo
209 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
