Question about Whirlpool GR448LXPQ Electric Kitchen Range
Burners cannot be adjusted always on high - Whirlpool GR448LXPQ Electric Kitchen Range
  • 999 Answers
Burner controls determine the setting so the controls are bad.
Eric
Posted on Dec 11, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
I have a Kitchenaide model KGSS907SBL01 gas range. Everything works fine except that we find that the amount of heat generated is disappointing. This seems to come from the fact that the top of the grill...
It would seem like reasonable thing to do.However the adjustment is typically for the low setting so you can adjust just the small flame just enough to simmer a pot without the flame going out from being so low its susuptable to going out on the low setting, also it so you can adjust the flame smaller so on low it isnt too high,causing it will boil when you intend to only simmer a dish your cooking. A question;is it all burners and have they always been that way?
Gene
Aug 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Front burner on grill won't adjust from high
Here is a couple of things to do.
Make sure your tank is filled.
Straighten Fuel hose, so it is not bent or kinked.
Does your front burner light with a match? If it does light then check the Crossover Ignition System.
Also, It could be the way the unit is turn off.
Try following thses steps, this will help to reset the excess flow safety device.
Turn all burner control knobs and the cylinder valve OFF.
Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve on slowly. Then go ahead an light your grill.
Fireplace-girl
Nov 15, 2007 | Weber Genesis Silver C Grill
Whirlpool GR448LXPQ Electric Kitchen Range Logo
63 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
