Question about LG Chocolate Clamshell VX8600 Cellular Phone
WHat is the unlock code to format a micro SD card for my VX8600
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
My micro sd memmory card has benn locked by a password by sum1 and it cannot be opened in any way so is there any solution i can open it. and i dont need any data in the memmory card. i just need it to be...
The micro sd has no lock tab to slide on the side, but the SD card adapter does. Unlock the SD card adapter, and format the micro sd card using a laptop or PC. The only way your micro sd card could be password protected is using encryption. If this is the case, formatting the card should remove the password.
Mar 10, 2011 | Lands Phones
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | SanDisk 2GB microSD Memory Card
Micro sd memory card lock password forgotten
Having 2 ways: 1. Insert the Card into any Nokia s60 OS mobiles having Microsd card, Nokia n95 Like then check this to unlock
http://www.mobiletipstricks.com/how-to-unlock-the-password-protected-memory-card-of-your-mobile-phone/
or Simply Put in Motorola Razar Mobile handset and format to have a fresh memory card
May 06, 2010 | Nokia 3110 Cellular Phone
Onknown format
The SD card format only goes to 2Gb, anything after this, is an SDHC.  You are obviously trying to use this with an R4 card or similar... These will only accept micro SD, and not micro SDHC
Jun 15, 2009 | Nintendo DS Lite Console
Unlock micro sd 1gb
hi,
first try to put the same code/password as of your old phone if it will work then good
otherwise
try to unlock with the new phone code.
if none of them work
then format the card from pc and format using FAT not FAT 32.
this will solve your problem.
Mar 24, 2009 | Nokia N95 Cellular Phone
How to unlock a micro sd memory card
memorey card locked . how to unlock my memorey card tell me
Sep 26, 2008 | Cell Phones
Memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Mar 08, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Music Help
Here is a link on how to use the Micro SD with a card reader to get music on your phone
http://bitrazor.com/content/vx8600/index.php
Dec 06, 2007 | LG Chocolate Clamshell VX8600 Cellular...
LG Chocolate Clamshell VX8600 Cellular Phone Logo
113 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
