Question about HP Compaq Presario V2000 Notebook
Weird Fan Noises and constant overheating
Hello, I've got a laptop, Acer TravelMate 3290 and the fan is always making weird engine type grumbling noises and the computer is always overheating. How can I fix this?
  • steeletudhop Nov 26, 2008
    squealing noise after it has been on for while
  • 520 Answers
Get yourself a sevice manual(if you cant find one can send u one)
take the cover off the fan ,take out the fan.clean it and check the rotor (dust collects there and develops into cotton like material)
replace components and reassemble pc.
if this doesnt solve the prob the seatings for motor have become worn and the noise is from vibration.you could try removing the motor and put some graffite in seating this acts like lubrication an minimises noise(dont use motor oil it attracts dust)
for the overheating...go into bios and select fan always on.(in advanced)
Posted on Mar 29, 2008
I dont know how to fix the fan problem but I know how to fix the overheating problem..
buy a laptop cooler pad
Posted on Mar 24, 2008
    Sergeant:
    Champion:
  • 244 Answers
Try to clean the cpu fan and also the door of thermal, it might be dust cause that noise.
Posted on Jan 20, 2008
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
I have a acer travelmate 5740. When I turn it on the fan whirs for 5 secs then stops. The computer doesn't start and the screen remains black. I've tried holding the power on button for 60 secs as...
hello sir!
it seems that *********** borad or power board isn't working. just take it to some machenic he will repair it in about 20$ or less..
thank you.
Apr 18, 2012 | Acer Computers & Internet
I've got an Acer Travelmate 292LMI. My problem is: the notebook starts (leds on) for only a few seconds (I can see the acer display that preceeds the boot) but immediately it is dead. Only the AC leds...
It could be an overheating CPU problem.
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Sep 06, 2011 | Acer TravelMate 292LMi Notebook
My acer travelmate 4200 laptop keeps turning of
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 19, 2010 | Acer TravelMate 4200 Notebook
Acer 602ter laptop beeps continuously
Something is wrong - RAM not properly "seated" into its slot, or "dead" CPU, or disk-drive not working, or it is overheating, because one of the "fans" inside the computer has failed, or has seized-up, and the fan no longer is cooling your computer.
Apr 07, 2010 | Acer TravelMate 602TER PC Notebook
Overheating although cooling fan & heatsink are ok
u r saying that the laptop is overheating. I think it is from cpu overheating right. just to make sure that it is cpu overheating, just go to the following link and download the software around 1mb which displays each and every component heating levels.
from that you can find out the exact component.
http://www.cpuid.com/software.php
if cpu is heating then just replace the thermal interface material and the problem will be gone.
if the cpu thermal interface material is too old then this type of problems arises
Apr 19, 2009 | Computers & Internet
Acer Travelmate 4650 cuts off unexpectedly????
add a desktop fan next to ur pc this will cool ur pc down ....if problem still happened call ACER costumer help
Mar 07, 2009 | Acer Aspire 5610 laptop vista combo with...
Acer travelmate 2350 wont boot or display
I have seen this on several ACER Laptops. It is always the Motherboard. Contact Acer repairs and order a new motherboard. IT will likely be about $200ish dollars. Then follow one of the guides on the web for taking your laptop apart and replace the board.
Feb 15, 2009 | Acer Computers & Internet
Problem in lan card of my laptop 2350 acer travemate
What type of connection are you using. Wireless ?
Jul 24, 2008 | Acer TravelMate 2300 Notebook
HP Compaq Presario V2000 Notebook Logo
333 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
