Engine idle fluctuates (rpms go up and down) and shuts off after running for about 5-10 minutes
  • 2,841 Answers
I would suspect a fuel problem. Replace the fuel filter if applicable. I would remove the fuel tank and clean it out throughly. Look on the bottom of the carburetor and you will see a bowl that houses the float. Remove the drain plug and drain the bowl. If you see any debris come out, then replace the drain plug and remove the bowl marking the orientation of how it was installed with a felt pen. Clean it out throughly and reinstall it taking care not to damage the gasket. It you do, then go buy a new gasket. Purchase a can of Seafoam Motor Treatment at most auto & marine parts stores & WalMart. This is the best Fuel System Cleaner and fuel stabilizer you can buy IMO. Follow the directions on the can and pour the correct amount of Seafoam in the fuel tank, and then fill it up with fresh fuel. Start the engine and you should notice it start to run better in a few minutes. If it dies let it set and start it again. If this does not help, then you may need to remove the carburetor and give it a through cleaning.
Posted on Dec 11, 2009
Why are all these codes being thrown in my Dodge w250?
What year is it? Your symtoms suggest oil contamination from bad fuel pressure regulator.
Sep 02, 2014 | Cars & Trucks
Idle fluctuates on 1995 f250, sometimes dies, sometimes revs, no apparent vaccum issues, IAC with scan tool reads low voltage issue. Could this be vaccum, charging system, faulty computer? Problem is...
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 08, 2012 | 1995 Ford F250
95 ford explorer idles for a few minutes then shuts off. Only when the engine is cold. When it is warm it dosent do it.
Oct 18, 2012 | 1995 Ford Explorer
Reabs up and down
Revs?
Engine stalls or RPM fluctuates at idle up and down.
Oct 15, 2012 | 1994 Honda Civic
My car is idling up and down
Engine stall or RPM fluctuates at idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Sep 17, 2012 | 1994 Lexus GS 300
Engine fluctuates when idle
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (USA) (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jul 24, 2012 | Cars & Trucks
I have a 1997 mercury tracer ls. When I speed up too quickly And then stop when I am idling sometimes the rpms tend to fluctuate from about 900 down to 500rpm a couple times then it will bog out. It olby...
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jun 01, 2012 | 1997 Mercury Tracer
My 1990 Celica won't stay at a steady idle. It will fluctuate between 1100 and 1800 RPMs every second unless I have it in a gear driving or rev the engine past 2000 RPMs.This started after getting it back...
Here are the most common causes of idle surge, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Jul 20, 2017 | 1990 Toyota Celica
1998 gmc 2500 4x4
check for vacom leak on engin intake
Mar 15, 2010 | 1998 GMC Sierra
Computers & Internet Logo
79 people viewed this question
Alun Cox
David Payne
David Payne
