Question about Acer TravelMate 240 Notebook
Bios Reset I have a Acer Travelmate 252lc_dt and i forgot my bios password and cant boot with my recovery cd. I need to change my boot sequinse
  • 4 Answers
Thereis a switch to remove bios password on the motherboard
http://slanyfree.net/howto.php?file=%2FHardware%2Facer-240-reset-password this is where it is and how to get to it
just move the first switch over and that will remove the pw
Posted on Feb 06, 2009
  • 26 Answers
Or you could short it out with a bit of foil...
Steve
www.yourhandinmine.co.uk
Posted on May 15, 2009
    Sergeant:
    Champion:
  • 244 Answers
Remove the battery from motherboard.
You should open the door on the back of your laptop,
if you can't see the battery, you might need to open everything.
Posted on Jan 20, 2008
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
BIOS password problem
DID YOU TRY ENTER IN THE BIOS? FROM THERE YOU CAN DO A PASSWORD RESET.
Apr 11, 2012 | Acer TravelMate Notebook
Can not sign in
if you mean that you cant login to your computer because you forgot your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change fist boot back to your hard drive) Hope this helps
Apr 02, 2011 | Computers & Internet
Reset bios password acer laptop 2410
PRESS F2 ON BOOT BIOS ENTRY THEN SECURITY CLICK THERE TO RESET
Jan 08, 2011 | Acer TravelMate 2300 Notebook
Need to reset the bios on Travelmate 4010, as it has BIOS password and HDD password locked
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 30, 2010 | Acer TravelMate 4010 Notebook
When my acer aspire 9300 laptop is turned on it says password i dont no what it is can u help
Well, I am providing you four tips which you can consider to recover Windows administrator password if your forgot or lost it:
TIP 1 - Use password reset disk
Windows-based system was designed to be able to create windows password reset disk without any other third party tools. So you can make use of a password reset disk to reset your Windows password in case you lose or forget your Windows password.
TIP 2 - Restore the operating system
Windows password recovery can be performed by restoring the operating system. Since restoration leads to data deletion, the solution can only work if you have a clean and updated backup of your hard drive data stored somewhere else.
TIP 3 - Use Windows Boot disk
The boot CD for Windows can be used to reset the administrator password. This disk enables you to repair Windows OS, thereby, setting your administrator password as blank.
TIP 4 - Use password recovery software
This is considered as the best windows password recovery solution, however, is to download a third party software. These tools enable you to reset Windows administrator password without posing any threat to your hard drive data. Among so many password recovery software, windows Password Recovery 6.0 is an easy-to-employ application which can be used to reset lost or forgotten password of any Windows system. Now execute the following steps to recover your lost windows password if you haven't prepared anything.
Step1: Login to a computer that can link to Internet. Download Windows Password Recovery from
http://www.recoverlostpassword.com/products/windowspasswordrecoery.html and install it on that PC.
Note that: there is an .ISO file. Burn the .ISO file to a CD/DVD or a USB flash drive
Step2: Get out the newly created CD/USB and insert it to the locked computer.
Step3: re-booted the locked computer (it's necessary for you to change your computer's Setup to make it boot from CD drive or USB drive) and then followed the process of instructions. Just a few steps, the old passwords were removed.
Step4: logon PC without password and setting the new password
Sep 24, 2010 | Computers & Internet
BOOT UP AND BIOS PASSWORD REMOVING
you have to open the back cover and there you can find  a CMOS battery located on the motherboard ....try to remove  and insert it ..it will reset the BIOS password ...
May 10, 2009 | Acer TravelMate 240 Notebook
Password on bios
well if ya have a bios password,reset the bios and the pass will be lost:)if ya have   a windows pass,put another user or if ya have admin password reinstal the  windows
bye
Feb 04, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate 240 Notebook Logo
679 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
