Question about Toshiba Satellite P105-S6124 Notebook
Toshiba laptop fan speed up and then slow down issue. Feedback
I have a Toshiba 17" with a Core 2 Duo 1.6GHz processor that has a Fan issue. Once in every 30 seconds or so the fan will speed up for a second and then calm down. It only does this on my XP OS. I dual boot to Ubuntu and don't have the issue on that OS. Thanks in advance and I will leave a positive 5 star rating for all comments that are somewhat helpful.
    Scholar:
  • 155 Answers
I have a toshiba and that is exactly what the fan is doing to cool off the processor. That is because when you boot XP the fan stops after 30 seconds is simply it has no difficult operation on it. But when you choose to switch on to Ubuntu your fan doesn't stop is because ubuntu requires more air since it has so much effort on its operation. Mind you when you installed ubuntu, it requires larger video graphics memory than the XP OS. Try to execute more websites on different tabs on your XP and you will find your fan will work overtime because you put much required operation for the processor. But to help the fan cools off the internal devices, place cooling pad beneath the notebook so that your PC will be safe.
Thanks...
Posted on Dec 11, 2009
Testimonial: "It doesn't sound like that on ubuntu. It never gets harsh and fast all at once- that has to be more damaging to my laptop.thanks for your opinion anw"
    Problem Solver:
  • 14 Answers
Fan speed is directly related to CPU utilisation. Check the processes running in Windows (CTRL+ALT+DEL) and select task list, click on processes then click on the CPU heading to display processes in order of utilisation. This will identify what's causing the CPU and resulting fan activity.
Windows is a "Chatty" operating system, whereas Linux is much more efficient, hence this explains why you're not getting this with Ubunto.
(Instructions to access task manager assumes Windows XP. Vista or Windows 7 will be similar)
SOURCE:
What is the processor fan speed for Dell Vostro A860?
This could be the result of to much dirt build up in the heat sink ports blocking vital air flow. Buy a can of compressed air and blow it on fan any open ports, this should prove if the fans the issue, the speed should slow down because of increase air flow cooling the laptop. If this works the machine should be taken apart for better clean out.
Mar 06, 2012 | Dell Vostro A860 Notebook
I have 2 problems: 1. can this type acer run mac os? 2. the machine came with duo core processor but i upgraded the machine by removing duo core and put core 2 duo 3.0 processor, now the machine is...
The answer to your first question is yes, your computer is compatible with the MAC OS. However it is very important to continue to ask this question to the MAC Salesperson you deal with when purchasing the software.
The answer to your second question is to do with Heat. Your computer is overheating and is therefore slowing down so it does not fry your CPU. You need to ensure that the Processor Heat sink is making proper contact with the CPU and the fan is connected to the computer main board. Clean the computer of all dust and install as many fans as your computer chassis will allow.
I think this chassis supports up to 80mm fans.
A well cooled computer chassis will work efficiently and effectively.
The Cooler Master Geminii S CPU cooler is a very good CPU cooler for your Processor.
It will reduce the temperature of your Processor by several degrees.
It is very important to get as much, cooler fresh air into your computer chassis as possible. As this will mean that your computer system will run at a far cooler temperature.
damnor01
Feb 08, 2011 | Acer Veriton M265 (PSV880Z001) PC Desktop
My Core 2 Duo CPU Fan has got a problem recently. Would any replacement of the Original CPU Fan be harmful to the computer? If there is any such problem, please let me know. Please suggest any CPU...
Try newegg.com, tigerdirect.com,directron.com,geeks.com. You want a Core 2 Duo cpu fan oem (socket LGA 775). Should be able to get one around 10 dollars or so plus shipping. You can pay more for a bigger fan but you really would not need it. OEM will be just fine.
Jan 11, 2011 | Intel Computers & Internet
Why my computer is too warm and shuts down repeatedly?
The issue seems with the cooling unit of processor.The unit is either dusty or faulty so you will have to replace/ clena it.
Thanks
Jun 15, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
I have Hp Compaq 6820s...and i have heating problem...my Cpu temp is around 90°C
The cause of this problem is first in the dust, which could have accumulated on the fan, which in the process of cooling the processor and chipset, chipset graphics card and motherboard as a whole and could be sensitive part of the temperature that controls the work of the fan has been by the damage and does not work and resolve This problem must be connected to the fan stream directly from the motherboard does not exceed 3 volts in order to operate the fan
Mar 14, 2010 | HP Compaq 6820s Notebook PC - Intel Core 2...
My Sony Vaio laptop makes a lot of noise mostly it seems from the fan. This is intermittent but seems to happen when I have had the laptop on for a long time. What might be causing this and is this serious...
Your processor is probably getting too hot. When it gets hot, the fan speed will increase. You will heed to have the processor heat sink checked, cleaned, and new thermal paste applied to it. You will also need to clean your cooling fans if they are dirty.
Nov 03, 2009 | Sony VAIO VGN-SZ645P2 13.3" Notebook PC...
When i have my entourage open my macbook slow down a lot i only have 1g of ram
If your Entourage database is rather large, it would definitely slow down your laptop. I'd highly recommend moving to the maximum RAM your laptop can take, even if your particular laptop can only take 2GB. Can you tell me the processor speed and model (e.g., 2GHz Core Duo or 2.16ghz Core 2 Duo)?
Oct 22, 2009 | Apple MacBook Pro Laptop Computer with...
What is the best?
Hi!
Thats not easy to tell....its all about money. But i will recomend you 3 verry good cpu:s that is not to expensive and worth the money.
1: Intel Core 2 Duo E6850 3,0GHz Box
2: Intel Core 2 Duo E8500 3,16GHz Box
3: Intel Core 2 Quad Q8300 2,5GHz Box
All of them are boxed, that means that you dont need to buy a separate fan
Nic
Mar 12, 2009 | Intel Core Duo T2600, 2.16 GHz Core Duo...
I would like to purchase a laptop. I'm confused about choosing a processor from intel dual core and core 2 duo. please help me choosing the processor
Intel Core 2 Duo is the latest laptop processor intel has made so it is newer than the original dual core. They have a few different cpu's so depending on your budget choose the core 2 duo with the fastest speed you can afford. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Computers & Internet
Toshiba Satellite P105-S6124 Notebook Logo
1,352 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
