Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a microwave oven of model:17PM-MEC of IFB brand.I want to know what is the work of Oven Air Vent.This is covered with a thin layer, Should I have to remove this layer or keep it as it is while using the microwave.
  • GE Master
  • 8,404 Answers
A thin layer of???
Is this a clear plastic cover in place to protect the finish? If so, remove it.
Probably best top remove it. Did you check your oven documentation?
Thanks for your interest in FixYa.com
Posted on Dec 11, 2009
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
For the sunbeam microwave sgb8901, do you take off the cover over the oven air vent? It's inside the oven on the right hand side- it looks like a rectanglar silver colored piece of cardboard.
I am also having this same problem i dont know the solution yet, but when you figure it out please let me know, or if i figure out i will repost =]
Aug 30, 2010 | Sunbeam SMW750 Microwave Oven
Model mmv1163dw00 had put frozen veggies in for 15 minutes, when done it beeped and then it went dead. I unplugged, tested my outlet which was okay. waited about and hour and plugged in and it worked. Can...
Yes, there is a thermostat on the magnetron that detects when it overheats.
When it does, it will shut down power until it cools back down.
This protects the magnetron from the destruction posed by overheating, which can be caused by:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
Check as many of these these things as you can and correct as necessary.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Let us know if we can help further.
Aug 21, 2010 | Maytag MMV1163DS Stainless Steel 1000...
We have a sharp 1480 and have to mount it with no outside vent. Can this be done? patqlt@verizon.net
Most of these over the range models come already set up for unvented operation. That is, set up for use with no outside vent. The oven will filter air through the a charcoal filter inside the upper grill and the vent covers underneath. If you ever wish to change the operation to allow the unit to vent outdoors, you need to change the direction of the blower fan assemby inside the top of the microwave oven. These instructions should be listed in the installation manual that comes with your oven.
Aug 16, 2010 | Sharp R-1480 Microwave Oven
Microwave work for 2 minut and turns off and after 5min its turns back on and do same thing
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
An overheating magnetron can be due to:
  • improper power line voltage (US homes should be 110-125VAC)
I would suspect a failure or the fan, clogged filter or bad magnetron.
You didn't mention your brand or model number, so I'm limited to general advice.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 26, 2010 | Amana RFS12MPS Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
■ Cavity light: The cavity light bulb is located behind the vent
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
May 06, 2010 | Maytag Over-the-Range Microwave
Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
Sep 16, 2009 | Frigidaire FMV156EM Microwave Oven
Looking to buy a top vent grille
Depends on the brand, but you can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If not, Please reply back with your brand and model number so we can help you.
Feb 11, 2009 | Amana ACO1840A Microwave Oven
Touchpad
sounds like your keypad is worn out, if you are able, this is most likely to be a modular part and could be replaced, (if you can find a replacement) the buttons are made of a thin deformed conductive sheet which makes contact when pressed to a flat layer underneath (seperated by an insulative layer) this flexable condictive layer becomes brittle with use and over time the edges of the flexable zones split. once that happens the button doesn't work you should be able to get a replacment keypad tho, or canabalise a dead one for the replacement keypad have fun :)
Aug 21, 2007 | Welbilt MR670TB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
130 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
