Mitsubishi Mr Slim Units Take 5+ minutes to start
I recently had some Mitsubishi Mr. Slim units installed in my home (MSZA09NA, MSZA24NA, and MSZ-FD12NA are the inside units and the outdoorcondensers are: MXZ4A36NA for the first two listed and MUZ-FD12NA forthe latter.) I've noticed that they take upwards of 5 minutes before they start spitting out any warm air. I can hear the beep after I press the remote which leads me to believe the command was sent. I live in the northeast but we haven't had any real cold days/nights that would ''freeze'' the condensers. Is this normal? Thanks.
  • 288 Answers
This is not abnormal. you dont have to worry about the refrigerant freezing. it wont. Once your unit is given the call for heat it can take 5 minutes easily for the refrigerant to circulate and draw the btus from the ambient air. you can try to change the setting on your fan to medium but no higher.
Posted on Dec 15, 2009
  • tim dulany Dec 15, 2009
    this is not abnormal. you dont have to worry about the refrigerant freezing. it wont. Once your unit is given the call for heat it can take 5 minutes easily for the refrigerant to circulate and draw the btus from the ambient air. you can try to change the setting on your fan to medium but no higher.
SOURCE:
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Msz a12na unitHOW DO I TURN HEAT ON? it worked fine last winter...? now the icon doesn't come up on any of the 3 units i have in the house.
Clean filters. disconnect from power for 10 minutes Reconnect and replace flitrs restart units. Set to heat on high.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/john_28069c9efb56199d
Nov 09, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a quad mitsubishi mr slim unit. one of the units was on during a power outage. We were not home so we did not see what happened but when we returned, the unit that was left on has the vent still...
Try to turn all of the power off for a few minutes and then turn it back on...this should reset everything again...
If not you will need to get a tech. to check it all out...
Here is a tip about Mitsubishi Air Conditionersand how to get the manuals for all of the Mitsubishi line. The manual includeboth troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Jul 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Just installed 5 units in my home. all four work
It sounds like the condensate from the drain pan is not draining correctly! The drain tube from your Air Handler unit may be kinked or not properly installed. The condensate water from the unit should be drained outside at least.
Jul 19, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
May 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Have a Mitsubishi Mr Slim and the indicator light is on in Heat mode, but no heat
turn the power off to it by the breaker and let stay off for about 20 minutes if its a lil glitch usually his will resetit if not ur going to have to call a repairman these are not like ur usual units and no easy to work on even for a technician
Feb 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim M/N MSH15EN
Try calling G A Larson's for technical advice. I think that they handle this product. 499-0866
May 22, 2008 | Mitsubishi Heating & Cooling
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
