Question about Dyson DC07 Full Gear Bagless Upright Cyclonic Vacuum
How do you change a brush head on the dyson dc07
  • 175 Answers
It takes a special factory tool to change the belt or the brush head. You will need to send it back the Dyson in Buffalo New York.
Posted on Dec 11, 2009
SOURCE:
Make brushes turn - band is intact but not turning the brushes
Hi there, it's Jack at Dyson.
Are you able to confirm whether your DC07 includes the brush control feature or not? The brush control would be a round dial on the cleaner head which allows you to turn off the brush bar when cleaning hard floors or delicate rugs.
If your DC07 does include brush control, make sure that when the vacuum cleaner is turned on and reclined, the brush control is set to 'Carpets'. The brush bar will never rotate when the brush control is set to 'Hard floors', or when the machine is standing in the upright position.
If you're confident your machine is already set correctly but the brush bar is still not rotating, or if your DC07 is a version which doesn't include the brush control feature, we'd appreciate the opportunity to provide further assistance.
I'd encourage you to give the Dyson Customer Helpline a call when you have your DC07 easily to hand so we can take you though some simple troubleshooting checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 03, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to change belt in dyson upright model dc07
There are two versions of DC07 - some include a brush bar which rotates all the time when the vacuum is running. And some include a brush control clutch mechanism which allows you to turn off the brush bar for hard floor cleaning. If your machine has the brush control, you'll see the dial on the front of the cleaner head.
If you have a DC07 without the brush control feature, you can replace the belt as shown in our online Support guide: http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if you have a DC07 with the brush control feature, the clutch mechanism uses belts engineered to last the lifetime of the machine in normal use. These are not designed to be replaced by the user, and we would advise against attempting to change these as damage may be caused to your machine.
For further advice on having your machine repaired, or to order replacement belts for a DC07 without brush control, please contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 30, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where is the brush belt on a dyson 07 upright vacuum?
The type of belt mechanism will depend on which model of DC07 you own. If you have a DC07 machine without the brush control feature, the user-replaceable belt is located within the cleaner head:
However, if your DC07 includes the brush control feature (you should see the Carpet/Hard floor dial on the cleaner head), your machine will use a clutch mechanism with belts engineered to last for the lifetime of the machine in normal use.
If you have a DC07 with brush control and would like some help with it, please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Cleaner not picking up
Hi Barbara, it's Jack at Dyson.
I'm sorry to hear the brush bar in your machine isn't rotating. Please make sure that the brush control on the cleaner head is set to 'Carpets' rather than 'Hard floors', as the brush bar will not rotate when the machine is set to the Hard floors position.
Please note, the brush bar will never rotate when the machine is standing upright, so make sure it's reclined into the normal vacuuming position before testing it. You might find our online Support guide useful when troubleshooting:
http://www.dyson.com/support/dc07/dc07-animalus/diagnosis-root-menu/flo-dc07-gen-i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/redirect-to-flo-dc07-clutch-does-the-brushbar-turn-with-the-power-on/flo-dc07-clutch-does-the-brushbar-turn-with-the-power-on
If you're still concerned about your machine after you've given this a try, please get in touch with us directly so our experts can provide some further advice. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 17, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dco7
you need to lie the dyson out on the floor/table and you will see some screws underneath holding the rotating brush in place, remove these with a torx bit and you will see how it lifts up to allow the belt to be replaced, just keep track of how things sit to make it easier to put back together
Mar 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
How to change belt on dyson DC07
If your DC07 is a model equipped with the brush control feature, a Dyson engineer would need to replace the clutch system for you. If you have a DC07 with brush control, and the brushbar is not rotating, please follow the steps shown in our online support guide to check everything is correct with the machine:
http://www.dyson.co.uk/support/help.asp?article=10&product=DC07-ANIMAL
If you've followed these steps and the brushbar is still not rotating, please get in touch with us directly using the contact details below.
However, if your DC07 is a machine without the brush control feature, please follow these steps to replace the belt:
http://www.dyson.co.uk/support/help.asp?article=18&product=DC07-SY
For further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Kind regards,
Jack
Dec 07, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to change brush belt on dco7 dyson
This depends on whether your DC07 has a brush control clutch or not. For excellent illustrated guidance go to www.dysonmedic.com and click on DC07. For belt change on a model without clutch click on "belt and brushroll". It's simple! For models with a clutch, click on "clutch replacement". It's not so simple!
Feb 16, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Full Gear Bagless Upright Cyclonic Vacuum Logo
79 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
