Question about Proscan Televison & Video
We have this proscan that was given to us,it played very good but now it keeps going off andon .now it won't stay on.we need help
    Genius:
  • 1,112 Answers
Hello:
First thing you should do is check all solder connections around the Flyback transformer for cold solder joints, The reason i say this is because u said it would go off and on, these sets were notorious for bad solder connections in the High Voltage area of the Board.If you know how to solder then this should solve your problem. Cold solder joints look grey or dull, They should all look shiny. The flyback is the large transformer mounted Vertically on the board with a thick red lead leading up the picture tube. Solder all the pins of this part even if some look ok... Good Luck
Posted on Dec 12, 2009
SOURCE:
I was given a proscan tv HDMI. I need to get a power cord and a remote for it. I do have the serial number.
If you have the model number of that Proscan TV, you will likely find the original remote for that at www.remotes.com. They don't have power cords for TVs, but they do have Proscan remotes.
Sep 05, 2018 | Proscan Televison & Video
The sound volume keeps going all the way up and wont stay to a normal level I have a32 inch proscan flatscreen tv
See if resetting the electronics to factory defaults cures the issue. If not, get some ear plugs till you have the main board replaced.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 23, 2017 | Proscan Televison & Video
Proscan.plt7100g played with it for 5 minutes and then lines began blinking across the screen. We powered off, put on charger and now when we power on the screen stays on proscan. What to do?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 15, 2015 | Televison & Video
My proscan won't stay on until it gets warm,
it was a common problem with an lcd tv, usually a leak or bulged capacitors in the power supply board will be the caused.
Nov 01, 2012 | Proscan Televison & Video
Proscan 40lc45s won't stay on
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Proscan 40LC45S 40 in. LCD TV
Proscan 32LA30Q won't power on
It appears to be a 32 inch.
Some questions:
Does power light come on and if so what color when set is off?
Were you having any problem before where you had to turn set on several times to get it to come on and stay on?
I am here to help you.
Mar 14, 2012 | Proscan 32LA30Q Television
Does anyone have the At&T U-verse remote codes?
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
May 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I cant get the DVD's to start playing on Proscan Tv
That is one problem with buying open box or display models. Ive learned the hardway myself. I'm guessing if this is the case you did not get a warranty with the item either.
The only thing I can suggest is that you buy a replacement remote from the manufactor. Seems proscan products are made by RCA.
This is a link you will be able to email them and tell them you need a remote give them the make and model of the TV, to get a price.
http://tv.rca.com/en-us/ContactUs.html
Good luck, and thank you for choosing Fixya!
Mar 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
While playing with PSP it suddenly gets stuck and screen goes blank
check battery, run without the battery, using ac adapter, see if problem persists did you update psp firmware? if so, undo the update, go back to previous firmware version
Aug 26, 2007 | Video Game Consoles & Games
Televison & Video Logo
16 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
