Question about Panasonic Lumix DMC-FZ18 Digital Camera
I am missing a large group of photos on my SD memory card but the photos that are on the card BEFORE and AFTER the missing group of photos are numbered consecutively with no gap in the numbering sequence. How could this happen? The missing group is pretty big (100+ photos) and the camera seemed to be operating normally at the time. Any ideas/ explanations/suggestions? Thanks!
  • 1,498 Answers
Hi Jame23a,
A memory card is structured like a hard drive. It has folders and they have sub-folders.
Many cameras automatically separate pictures that were taken at different settings (image size, resolution, motion) into their own sub-folders.
When accessing them from a computer, the separation is easy to see. On the camera, not so much.
There is an option in viewing to select the images. The sub-folders that separate your pix will be grouped in with the rest of the pix on the primary storage folder. Select that.
Best regards
Mike
Posted on Dec 11, 2009
What does back-up to sd card mean?
the camera has internal memory and also will have the option for external memory. If you have a sd memory card in the camera you can backup the internal memory to the sd card.
Then you can remove the sd card and put in a new sd card and you now have an sd card with your precious photo memory's copied from the camera internal memory. You may have a camera that allows two sd cards one for the photos and one to back up the photos. If you had your camera stolen or lost you would lose all the photos on the camera but with a backup sd card you still have the photo files. Also a p.c with a card reader device could read the files on the sd card and you could copy them into a cloud storage on the net or onto a network storage device or onto a usb portable drive with 2 terrabyte capacity .
https://en.wikipedia.org/wiki/Secure_Digital
Jan 29, 2016 | Cameras
My camera shows formatt error when i switch on it. the memory card s not getting formatted. oly 2 options r showed format or switch off..... plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz helppppppppppp.. i
You may have to large of a sd card. If it;s larger than 1mb then you may want to try using another that is smaller. See if that helps you out! Good-luck!!
Apr 06, 2012 | Olympus FE-210 7.1 MP Digital Camera w/...
Camera formated sd card with photos. any way to recover lost phots? JERRY
Hi, gschlatt. You have great chance, do not miss it. It is quite possible to recover the photos no matter deleted, formatted, lost or inaccessible from your sd card. All you need to do first is by trying SD card recovery software tools.
Note: before those files are recovered, never should you attempt to save more data to the card. better stop using it for a moment. Hope it helps. Regards.
Mar 27, 2011 | Casio Exilim EXZ75 Digital Camera
After taking only two -three photo , camera is displaying memory full, please help me with this
Hello - You're camera has a little less than 10 MB of memory with sounds exactly right (2-3 photos) with a 12 megapixel camera. Such images are large.
You need to purchase a memory card to insert into your camera to store pictures. Your camera takes several kinds of memory cards but I suggest your purchase a SD memory card of two GB in size. You can get them almost anywhere, Super Markets, Chain Drug Stores, Places like Walmart, Kmart, etc. It'll cost about $15 or so.
Happy Photo Snapping, Mikeywaf
Mar 09, 2011 | Samsung SL605 Digital Camera
Photos taken now not visible on memory card. I'm currently on vacation and have been taking photos on my DMC-TZ5. Camera has been working fine, until yesterday. I took a number of photos of a...
The memory card has most likely corrupted or the camera itself is faulty. Depending upon where you were holidaying this could be an intermittent fault due to temperature or humidity. It can also be caused if you have not followed the correct procedure for safely removing your SD card from your laptop (in Windows, click on "safely eject hardware" or from the "My Computer" window right click the SD card icon and select "Eject").
Try cleaning the card contacts using a cotton bud moistened with alcohol in case sweat, oil or grease has got onto them. If that fails then see if you can borrow another SD card, but this is risky as you may end up damaging the card so you may be better to buy the cheapest one you can solely for testing purposes (it's also worth asking for one on your local FreeCycle /Freegle groups as many folks now have low capacity SD cards with zero resale value which they have upgraded from and no longer use) . If the camera works perfectly then you know that it's most likely that the card was at fault and if not you definitely have to choose whether to get your camera sent for diagnosis and possible repair by Panasonic or whether to buy another one. Your camera is recent enough that it might still be under the manufacturer's warranty.
Regarding your existing SD card, it seems not to have recorded the images correctly or may not have recorded them at all. If the former applies, they *might* be recoverable but it needs specialist data recovery software which is not cheap (search "SD recovery"). Insert the SD card into your laptop and select the three black frames and click on "properties" to see how much memory they occupy. This will give you an idea as to whether there are approximately 90 images (3 x 30) there or not, but even if not the images could still be elsewhere on the card. You really won't know unless you invest in the required software to find out or by taking the card to a data recovery specialist (also not cheap). If you hope to recover any lost images then you must not use the card again as the data will gradually become overwritten.
The final option is to abandon all hope of the lost images, transfer the ones which you do have to your laptop (and back them up further to recordable DVD or a USB stick) and to then reformat the memory card in your camera. This option is only to be taken if obtaining a replacement SD card is impractical and if you wish to gamble that the fault was an unusual one-off. Only you can decide whether the risks of losing further unrepeatable photos are an acceptable alternative to the only certain (and expensive) fix of buying a new camera and/or memory card, although you could recoup some of the expense by reselling your current camera: it's up to buyers to ask questions ("caveat emptor") so don't mention the recent issues. Morally and legally this is fine as you don't actually know that the camera is faulty.
Sorry there's no definite answer here, but I hope that my reply will help you to isolate the cause or assists you in choosing your next course of action. If the fault is intermittent then they're impossible even for professionals to repair if they cannot reproduce the fault when testing the camera.
Good luck, and please take a moment to rate my answer.
Sep 30, 2010 | Panasonic Cameras
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
May 31, 2009 | HP Photosmart R817 Digital Camera
Memory card
Have you formatted memory card in phone before you started storing data on it? By formatting the memory card it will set up folders which the phone will look at to determine different types of data, i.e. photo folder holds photos, video folder holds mp4 &3gp, and music folder holds mp3 etc.
Then when your memory card is connected to your pc drag and drop data into correct folders and then phone should be able to recognise the different types of data. Hope that helps?
Only other thing I can think is that your memory card is too large to be recognised by your phone? It will only support upto and including 2gb Micro SD cards.
Apr 24, 2009 | LG KU990 Viewty
Missing pictures on sd card
I had success with this
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download SD card photo recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Mar 29, 2009 | Kodak EasyShare C613 Digital Camera
Can't access photos on 2 GB SD camera card.
You may try some photo recovery software to rescue the files on your digital camera sd card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Mar 22, 2009 | Canon PowerShot A540 Digital Camera
Missing memory card
In all probability the memory card that came with your PDR-3300 was:
SD 8 MB Toshiba Memory Card.
SD cards with a much larger MB can be obtained at any large Drug Store, i.e. Walgreens, CVS, etc.
At the present time, these cards, 32 MB and larger are very inexpensive.
Feb 18, 2009 | Toshiba PDR-3300 Digital Camera
Panasonic Lumix DMC-FZ18 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
