Akai, pt4298hdx-sms 2003, it has two colors and in waves
We have a pt4298hdx-sms 2003, it has two colors running horizonal, green, red, also text was in 3d.
  • 834 Answers
The convergance ic's have failed they are stk392-110 you will need 2 and they run around 24 to 25 bucks a piece you can get the complet convergance board for around 75 dollars on that set it is located up mounted to the crt bracket try partsearch.com of shopjimmy.com
Posted on Dec 11, 2009
We ahve an Akai Projection TV PN# PT4298HDX/SMS TV turns on but no picture
Sounds like your bulb went out, I would call the manufacture or a local TV repair shop to find the part.
Akai Corporate: 323-281-0782
Aug 27, 2011 | Akai Televison & Video
Wavy horizonal disturbance in picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Televison & Video
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
My tv is blurry, showing green and red waves...zenith d61w25
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Akai model pt5598hdx/sms
it would sound like your convergence amp power board has failed at the shop we would replace then it would need a serviceman alignment
Jun 17, 2009 | Akai PT5598HD 55" Rear Projection...
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
AKAI MODEL#PT4298HDX/SMS RED TIMER LIGHT JUST KEEPS BLINKING
Do not panic! Do not throw your TV away like I wanted to! Here is whatmay be the solution for most of the members who have posted theircomplaints here recently. I am not an expert, but I followed all blogsfrom various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it fromwww.partstore.com and since this Akai is the same model as the SamsungModel # HCN4226WX/XAA, buy the Samsung BP95-00142E Convergence boardfor $77. It came to about $85 after shipping. The Convergence board hastwo black STK ICs and two colors of wires, a gray kind and a bluekind, all which have 'pins' and can easily be unplugged from thecircuit board in the TV. It is basically a complete system that takesless than 30 minutes to install. It is a simple swap procedure, with nosoldering. You only need the new board and a screwdriver! Remove thelower back board of your TV where the cables are plugged in (do notunscrew all the screws for the screen, as it is unnecessary, and mightjust damage your screen if you are not careful.) It has a u-like shapeand comes off easy. Detach the gray wires connecting your old board tothe rest of the circuitry, and detach the blue wires connecting the oldboard to the circuitry. On the old board, there are connectors marked,from left, blue, green and red. Detach those from the old board, andmark the wires so that you may connect the correct the wires to the newboard. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks whichheld the old board, and screw the lone screw to the board. Plug thegray cables from the new board to the connectors where the gray cablesfrom the old board were,and do so for the blue cables. Connect themulticolored cables to the blue, green and red, just as was done on theold board. Reattach the cover and test the TV. Please do not replacethe two STK ICs only. When I removed my old board, I realized thatthere was a burn mark, where the ICs were, but maybe it was a fuse. Youmay replace the ICs only to discover that it was another problem. Goodluck, and I wish you all the best in the repairs. I just saved about$100 for a repairman just to show up
Dec 09, 2008 | Akai PT4298HD Rear Projection Television
Fuzzy Blue...?
these set are bad about the blue tube messing up.. what happens is the convergence board witch generates alot of heat cooks the blue glycol.... basically growing algea in the blue tube... it is possible to remove the tube.. and remove glycol and clean the tube then replace and adjust..i have done a few here at the shop
Mar 14, 2008 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
