Question about LG Prada KE850 Cellular Phone
Prada phone my phone only rings three times too. How do you cancel call divert?
I had the same problem I called my network provider and they give you a long winded code to put into your phone to lengthen the ring time.
shaz
Posted on Jan 30, 2008
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
My phone rings 3 times and then goes to voicemail. Many times I cannot get there in time and I would like my phone to ring five times before going to voicemail,
Look at your call forwarding or divert settings, change the settings to cancel all diverts or to divert to voicemail only when the phone is off or not answered. Chances are that all calls are currently being diverted to VM
Jan 21, 2015 | Office Equipment & Supplies
Phone does not ring goes straight to voicemail
hello, its is possible that you have activated your call DIVERT...
Try to deactive all call DIVERT on your phone device.. Go to your settings, check CALLS SETTINGS, THEN YOU CLICK ON CANCELL ALL DIVERT..
cheers.
May 13, 2010 | Lands Phones
Nor ringing long enough before going to voice mail
Try going into your settings/call settings/call divert.
Go into Call Divert and cancel all diverts.
This should solve your problem.
Aug 26, 2009 | Nokia N73 Cellular Phone
Sony Ericsson z750a incoming rings end too quickly.
cancell all call diverts. it may be happening due call diverting.
Jun 04, 2009 | Sony Ericsson K750i Cellular Phone
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
Dec 17, 2008 | LG CE110 Cellular Phone
PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Feb 15, 2008 | Pantech C120 Cellular Phone
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Jan 15, 2008 | Nokia 7250i
How do i get my prada phone to ring more that just 3 times
u need to cancel all your diverts on ur calls and tha should sort it out for you
Jan 14, 2008 | LG Prada KE850 Cellular Phone
LG KE850 prada phone - call divert timings
This is an operator supported feature. You need to punch in this code.
**61*destination*11*nn#[SEND]
destination is the number the calls get diverted to
nn = time in seconds (5/10/15/20/25/30)
This will work if you operator have not disabled this code.
Dec 30, 2007 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
