Question about Brother MFC-8460N All-In-One Printer
How do I set it to receive a fax? I'm working in an internet cafe and people are trying to send me a fax but it won't let me. How do I do so?
    Brigadier General:
  • 10,406 Answers
Use a 4-wire telephone-cable to connect the telephone-port on the unit to a live telephone-jack in the wall.
Use your cell-phone to "dial" the telephone-number associated with that telephone-jack. Listen on your cell-phone for the unit to "ring" and for it to "answer" the telephone-call. If it does not answer, check the configuration on the ALL-IN-ONE.
Posted on Dec 11, 2009
I have a canon IR 1025IF that will not receive faxes but will send faxes
You should check your telephone and fax set up. Also check the settings on the machine to see if it is set for Manual receive or Fax/Tel, and the number or rings before pick up. If you are on an ADSL internet connection, you should fit or check that the line filter is working. The Fax line should be connected through the filter
Oct 31, 2017 | Canon Office Equipment & Supplies
Fax problem
But can you receive a fax from that line also?
Aug 04, 2008 | HP Officejet 5610 All-In-One InkJet...
FAX will not send nor receive.
Free Fax Free Internet Faxing
You could try this if you have a normal computer scanner or the document is a file on your computer before being printed. Sounds like your fax machine is simply broken.
Feb 06, 2014 | HP LaserJet 3050 All-In-One Printer
Cant fax from my canon mx 432
Think there's something wrong with your settings.
Actually, if you want problems like this to get lost, just use an Internet fax. There's a plenty of services - Popfax.com for example. They make all the work for you and you just have to send and receive faxes, no headackes with settings)
Feb 25, 2013 | Office Equipment & Supplies
HOW TO EMAIL SCANNED DOCUMENTS FROM HP J4580 DIRECTLY?
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
Jan 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
Seems I can send faxes but have problems with receiving.
That's a driver problem. Uninstall the driver first before reinstalling it.
Apr 09, 2017 | NexxTech NSFTMD1
Cannot send or receive faxes.
Try a phone hand set on the wall jack to make sure you can get a dial tone and the line is alive.
Then plug the fax phone line into that wall jack. Make sure the phone line is also in the right port on the back of the Officejet printer, where it most likely says LINE -IN and NOT where it shows an image of a phone set.
RDO
Nov 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-8460N All-In-One Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
