Question about Dell Inspiron 1525 Notebook
How can i take a key off the keyboard to clean under it?
    Brigadier General:
  • 10,406 Answers
STOP. Rather than doing that:
1. Turn the computer off.
2. Remove the battery.
3. Buy some Q-Tip(tm) and Denatured (pure) alcohol, and a can of compressed-air.
4. Keep the can upright, and give the keyboard a "blow-job".
5. While you're doing it, shoot the compressed air into every intake/exhaust vent that you can find. Dust inside the laptop creates heat, because it "insulates", and heat creates problems.
6. Dip a Q-Tip into the alcohol, and gently clean the keyboard.
7. Let the computer dry-out.
8. Reinsert the battery.
9. Reconnect the AC adapter.
Posted on Dec 11, 2009
SOURCE:
Some keys do not respond
Disconnect and reconnect your computer keyboard, then restart your computer. Sometimes a poor connection can result in keys not working on your keyboard Update the device driver for your keyboard by going to the manufacturer's website of your keyboard, and then download and install the latest driver matching the brand and model number of your keyboard. Disconnect your keyboard from your computer and inspect the pins in the keyboard connector if you have a PS/2 connector. The PS/2 connector for your keyboard has six pins, which connect into a PS/2 port of your personal computer, to allow for communication to and from your keyboard. Straighten any bent pins you may find, by gently using a ballpoint pen. You must replace your keyboard if you see broken pins. Try testing your keys using a different application, such as another word processing program. Keys like the function keys on your keyboard labeled F1 through F12 may not work in one application but will work fine in another. Clean Under Desktop Keys Disconnect your standard desktop keyboard, then press down on a key not working. Slip a car key or a flathead screwdriver underneath the key. Twist the screwdriver or car key until the keyboard key pops off. Use a damp cloth, moist cotton swabs or compressed air to remove dust, hair, and food crumbs under the key. Use only water or rubbing alcohol to moisten the cloth and cotton swabs---other cleaners can damage the plastic of your computer. Position and press down on the key to snap it into place. Repeat this for all of the keys to clean underneath them, if necessary. Clean Under Laptop Keys Turn your laptop off, then use a flathead screwdriver or knife under a key corner, prying the key off gently. You will hear a snap as the key detaches. Remove the key retainer remaining on your laptop using your knife or screwdriver under the corner, then popping it off with a gentle twist. Remove the space bar by pulling it off after your insert the screwdriver or knife underneath the bar. Clean underneath your laptop keys using cotton swabs or a soft cloth dampened with water or alcohol. You can also use compressed air to remove dust, hair and other debris. Replace your laptop keys by placing the key retainer into position. If you cannot remember the position, copy another retainer's position by removing another key. Insert the keypad into the retainer, then position the key over the retainer while pressing down on the key. You should hear the key snap into place. Place your laptop's space bar over the space bar slots, then snap it into place
Feb 13, 2013 | Everex StepNote XT5000T Notebook
What is the problem why the arrow keys functioning differently.
hope this helps
Oct 14, 2012 | Unotron S5100KG Keyboard
Have a HP Pavillion 3163cl Entertainment Laptop and the Space Bar asks like someone is pressing down on it at all times. Like a stuck key and makes the noise when turning it on. The Laptop belongs to my...
To clean your laptop's keyboard you have to look under your laptop, you can see like keyboard icons with some scews, so, open them, they will let yout to remove your keyboard.
So now your can remove just your keyboard slowly for some connectors on the motherboard then clean it with a tooth brush.
You can only clean your keyboard with a toothbrush without rmoving it,
Try to remove the space bar key and clean under it.
Try to hard press the space bar for about 5 times, it can release the pusher under the key.
it some liquid was spilt on it you have to remove the keyboard and clean the plastic under ther keyboard.
Good luck
Jan 20, 2011 | Computers & Internet
Random keys will stick every 5-10 minutes of use
Usually caused by some liquid or dirt getting under the keys, you can try blowing a can of compressed air under them to try and clean them, or if you have the patience of a saint, can remove and clean each key in turn with ethyl alcohol (not advised), failing that, a replacement keyboard is the only solution
Jan 04, 2011 | Dell 0Y3740 Keyboard
My keyboard automatically typing letter z and /////////... continuously even without pressing my keyboard. how can i solve this problem? thanks..
One of two things are happening. Either your keys are stuck due to debris and/or dust on your keyboard or someone has created "hot keys" possibly as a joke and they are typing it. Get a coin and insert it under the key and pull upwards. Keys pop on and off the keyboard. It will not hurt it. Remove both keys and check for dirt and dust under them. If this is not the problem then you have hot keys set. In order to walk you through disengaging them I would need to know your operating system and if removing and cleaning the keys worked first. Please let me know this by going back to your original question posted on fixya and using the comment or reply button.
Nov 28, 2010 | ASUS 90-A4C1K1000 Keyboard
Letter 0 and will nt type
Keys go bad.
Most keyboards are capacitive, so it isn't an actual switch under each key, but sometimes it's just crud under they key
Try popping the key off, cleaning underneath it, and replacing they key.
Feb 01, 2010 | Microsoft Wireless Laser Desktop 4000...
How do i fix a key on a keyboard that is not typing the letter all the time
things to try:
1. Blow the dust out of it and clean the crud out from under the keys.
2. You can very gently pop out the key and remove the little rubber cap under it and clean the contact. I usually use a pencil eraser very gently. also clean under the little rubber cap a bit. and reassemble.
3. Worse come to worse swap out the offending key assembly with the ~ key. and relabel the new key with either whiteout or a magic marker depending on key color. Also great for laptops that are missing keys.
4. get a new keyboard.
Sep 10, 2009 | Apple Macintosh Keyboard
Keys are sticking the keyboard. Can i clean underneath the keys?
Depending upon how sticky the keys are, it might be easier to buy a cheap replacement keyboard.  Trust me, it takes a whole lot of patience and a steady hand to take apart the keyboard key by key and then put it back together.
Mar 09, 2009 | Toshiba Computers & Internet
4 keyboard keys aren't functioning
Chances are there is a physical problem with the keyboard. Are the keys sticky or do they press normally and still not work? If the keys are sticky when you push them you can remove the keyboard and keys and try to clean the keys with rubbing alcohol. Chances are the keyboard is not defective and the link below will help you take care of that problem. If you need any further help let me know.
I am including a link to a new keyboard for your model Laptop. They are fairly reasonable condidering they are laptop keyboards.
Jan 09, 2009 | Acer Aspire 3000 Notebook
Logitech cordless keyboard erratic after cleaning keys
seems to be that you may have accidentally swept some dirt underneath the keys.
try pressing each key individually in word and narrow down the affected key or keys, then remove the affected keys (using a keyboard key removal tool, or very carefully by hand) and clean underneath the key with a small dry clean brush both under the key and the board section it lay in, then replace the key and type the key again, if that has no luck then try the process again.
hope this helps
kev
Dec 01, 2008 | Logitech 967437-0403 Keyboard
Dell Inspiron 1525 Notebook Logo
112 people viewed this question
Clive
Clive
Alun Cox
