Question about Refrigerators
I have an Amana Bottom freezer refrig model ARB2117BS need to replace defrost thermostat. What do I need to take off inside the freezer to access the thermostat? I have the freezer door off. Does the ice maker have to come out or just freezer back panel? Is there anything else like side freezer panels that need to come off? I have the back of the refrig already off but not accessible thru the back. Mark
  • 1 more comment
  • aslick_alice Dec 11, 2009
    Thanks I need info on my brand not generic at this point. I've already been down that road.
    You have helped a lot because my main concern was what I needed to remove. I am replacing the defrost thermostat is the rest of your directions to replace the defrost timer or the defrost thermostat?
  • aslick_alice Dec 12, 2009
    Thanks this was a great help. Got the back off and can now see the thermostat and ready to test it.
  • 520 Answers
You are on the right path. Go ahead and remove the two screws at the bottom of the ice maker and lift it up and away from the freezer wall. Now you will need to un-plug the ice maker. You should be able to remove it now. next you will need to take out the screws that hold the back panel and lean it towards you to remove the ice maker receiving plug. Now the fan should be attached to this panel. Go ahead and disconnect it to remove the panel all the way. You should now see the evaporator coil. There should be a couple of black wires going to a thick disk like piece that is attached to a pipe. This is your defrost timer or clix-on. You can trace the wires to remove it but I usually cut them and add spade connectors in line. This helps in future changes. Now you can remove the clix-on disk. There is a strap clamp that holds it to the pipe. Use a screw driver to pry it off. Install the new one in the reverse order. Hope this answers your question. Good luck. Please accept and rate if this has helped. Thanks cj2176.
Posted on Dec 11, 2009
  • 126 Answers
The inside freezer wall has to be removed.The icemaker and tracks (slide out drawer) have to be removed so the wall will come out.,Once that is done you will see the defrost stat on upper left or right corner of evaporator.Make sure power is off ,you may have to cut and splice depending on the replacement you got.Tstat is 2 wires and it doesnt matter which way they go.If the refrigerator has not been defrosted you will need to do that first tstat could be covered with ice .Hope this helps. Please rate my response :)
  • 10,515 Answers
I have a Generic Procedure which might help you :-
http://www.acmehowto.com/howto/appliance/refrigerator/repair/defrosthermo.php
If still unable to fix it, let me know so that i could check extensively for you.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE:
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
I HAVE A GE MODEL GSS20IBTAWW.. LOOKING AT A DEFROST PROBLEM.. DOES THIS MODEL HAVE A DEFROST TIMMER OR A DEFROST THERMOSTAT OR BOTH ??? AND ALSO THE LOCATION WOULD BE HELPFUL... THANKS, DAVID
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Aug 08, 2010 | GE Refrigerators
The refridge side of my GE side by side is not working. However the freezer side is freezing up. I believe it may be the Defrost thermostat or the defrost control that went bad. How do I test these.
Without the model number , I will assume the refrig is 10 yrs old or less . If so , would need model number to give you the correct part number for the heater . This test will still tell you what the problem is .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
Jul 18, 2010 | GE Profile 21.6 cu. ft. Side-by-Side...
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Frig frosted up and quit cooling
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off at selected temp .
Apr 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
My ge side by side model gss25jfmc ww will start to freeze food in the cool side then it stops cooling in the freezer side. Ice will form on the back wall of the freezer. I haved thawed it out &...
I can tell you how to find the problem , but , it is a little work .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator the evaporator keep freezing , i had clean out the ice ,but after 2 , 3 week it freezing again , can please let me know . my refrigerator model-gsh25jstass
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater ( pt. number WR51X10055 ) . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have an Amana bottom freezer, model BX20S5E that is not cooling properly in either compartment. I have replaced both the defrost thermostat and defrost timer (new). Still no change... what I do notice is...
check door gaskets and see if problem is moisture,or air gate to fridge compartment not working properly.I would recomend verifying defrost cycle is working by turing defrost timer to defrost cycle,it will click when engaged when unit is frozen and heater should come on if all is well,if not heater is probably culpret if the rest is new.
Apr 09, 2009 | Amana ARB8057CSL Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Marvin
Marvin
