Question about Dynasty DGRSC 48-4GCB Gas Kitchen Range
Dgrsc , both burners off both oven are burned and the customer is scared to light them up
5 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: my oven makes an electrical burning smell when
how old is the unit and can you hear any odd electrical arcing noise from the unit,? outside of the usual low hum of the elements heating up?
Posted on Sep 24, 2009
  • 93 Answers
SOURCE: Replace Dynasty Range oven light lens?
Call Dynasty / Jade ph # 800-884-5233
Posted on Mar 02, 2010
SOURCE: The Oven Won't Light
The igniter must draw approximately 3.0 amps before it will open the gas valve to allow the oven to function. Place a clamp amp meter on one of the leads and check the amount of current. If less than 2.9 amps replace the igniter. You can find it on http://www.ignitors.com/oven-ignitors/dynasty.html
Posted on Oct 30, 2010
SOURCE: I have a dynasty DGRSC-30-4
Are you using natural gas or LP??
Posted on Dec 12, 2010
How do I re light oven pilot light. Top burners fine
This oven has an electric ignitor. It does not have a pilot light.
Oct 19, 2010 | Dynasty DGRSC 30 Gas Kitchen Range
Pilot is on but oven won't fully light
Hello, I think I know what your problem is...if you're referring to the oven bake burner it is the hot surface ignitor which is failing. If you're talking about something else let me know, otherwise swap out the bake ignitor and you'll be fine. Thanks for visiting "fixya" and good luck. Macmarkus :)
Apr 15, 2010 | Dynasty DGRSC 30 Gas Kitchen Range
Oven does not "burn" steadily when set below 300 degrees.
Sounds like you have a bad oven ignitor and oven burner tube. install a Amperage meter on one of the oven ignitor wire, It should draw above 3 AMPS, if it is below then you have a bad oven ignitor, or just change the oven ignitor to see if it makes any difference. Have fun.
Dec 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
Explosion in heating chamber when oven is lit.
the air adjustment is open just a little to much the flame will have a hard time to go to the other side, try closing the vent to the burner just a Little bit and try the oven,another problem that i see is that the ignitor is getting to weak to ignite the flame on time.
Dec 09, 2008 | Dynasty DGRSC 60-6G Gas Kitchen Range
Oven burner
try ajmadison partsquik. com   enter the model number, its on there and available for about $140
Nov 26, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Dynasty model dgr-336b mfg.1993 converted to propane serial #040692h
pull up the floor of your oven and look at the burner, have any of the small gas holes rusted out in to bigger holes? Sounds like it is possible that most of the gas is now coming out a 'burned out' hole rather than the small neat row of normal holes. Good luck.
Jul 14, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Dynasty range, oven does not heat up enough
30 inch oven has only one oven tube, 36 inch oven has 2 burners in it, most comment is the oven ignitor is out. If you have 2 burners, I'll change both oven ignitor at the same time, because they worked together. also check the oven tube, if it is corroded at the ignitor area, change the burners. Have fun.
Mar 22, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Dynasty DGRSC 48-4GCB Gas Kitchen Range Logo
44 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
