Question about Freezers
Does the lamp f48t10cw have to be the same or can you use a different lamp like f32t8cw?
  • Freezers Master
  • 1,280 Answers
No, you can not substitute a T8 for a T10. Don't do it. You can change the color such as a ww for warm white, cw for cool white, and so on but that's it.
Posted on Dec 13, 2009
SOURCE:
Why does the light flicker when door is opened. The freezer seems to be working at this time.
It could be the button door switch that controls the light, or that a florescent lamp is being used in the cold fridge,
Oct 30, 2015 | Frigidaire Freezers
How to replace small light in top of chest lid
lever off the plastic cover, unscrew and replace the lamp
Sep 08, 2015 | Woods Chest Freezer C1501W3
The power light is faint and flickering on and off
These power lights are usually of the neon lamp type, and they typically do not last a long time, especially when they are powered on 24/7. They typically fail by flickering at first, then, eventually, they just go out. If you feel confident as a "do it yourselfer", you can often replace this lamp for only a few bucks, but it does require disassembly of the control unit. Otherwise, I'd just leave it alone. If you're concerned about food loss, I'd invest in a freezer alarm. The lamp has no bearing on the operation of the compressor unit. On, flickering or out completely, the freezer will still operate normally.
May 27, 2014 | Danby 3.6 cu. ft. / 102 liter Chest...
There is no power fridge will not run
Put more coins in the electric meter! lol
Check socket with working desk lamp
Check fuse in freezer plug
Apr 02, 2014 | Woods Upright Freezer MU07W
Why is the power light flickering on my Emerson 3.5 cu. Ft. Freezer chest model CF450
Just noticed your question from 2012 - my answer is probably irrelevant by now, but here goes. The power on light is of the neon lamp type, and they will often fail after a year or so, typically by flickering, then getting dimmer and eventually going out. If you feel confident, you can replace this lamp for only a few bucks, but it does require removal and disassembly of the control unit. It would probably cost more than the freezer is worth to have an appliance tech do this. The lamp has no bearing on the compressor function; the freezer will continue to work with or without the lamp. If you're concerned about food loss, you might consider investing 25 or 30 bucks in a freezer alarm. Hope this helps.
Oct 03, 2012 | Freezers
Light doesn't work
First check the lamp; make sure it isn't loose in the holder,check the filament is still complete. Next check the light switch has power and is closing with the door opening. If no power, check wiring/ connection. If power in and out can only be the lamp!
Jun 11, 2012 | Frigidaire Freezers
My freezer is not working it is 40 degrees in side, lights are working
Hi, Your compressor was die and lamp switch is broken. Need to replace them.
Oct 17, 2010 | Frigidaire 13 cu. ft. / 368 liter Chest...
Light removal
get a screw driver and loose the light holder and replace it a new one bought .
May 03, 2010 | True 23 cu. ft. / 651 liter Commercial...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
