Question about Goodman Heating & Cooling
Goodman GPM075-3 air conditioning connections
Goodman GPM075-3. I need to know where the two wires from the outside compressor hook up on the board. The blue wire from the tstat (which controls the cooling) should connect with one of them. Where should these wires connect?
  • 12 Answers
Your thermostat powers 'Y' for cooling. That in your case blue wire connects to 'Y' on the control board in the furnace. Then a pair of low-voltage wires connects 'Y' and 'C' on the furnace to the two wires to the coil of the contactor in the a/c condensing unit. So to follow the path, the signal wire from the thermostat sends 24v down the Y wire to the furnace board Y terminal which also connects to one side of the contactor coil in the air conditioner. To complete the control circuit to the air conditioner there has to be a common wire. This is connecting the C wire from the furnace board to the other side of the contactor in the air conditioner. Hope this helps.
Posted on Dec 11, 2009
Have a 3 year old Goodman Compressor GSC130301AE. Compressor shut down with very hot outside temps, now works occasionally, compressor not starting after a start up, despite 90' temps today.
this could be a stuck compressor or a low voltage condition shut it down as the compressor is only getting hotter. wait about 1 hour and tryagain hope this helps let me know Jon
Jul 25, 2011 | Goodman Heating & Cooling
My A/C turned off. Still blowing air around. Hot air. Outside the A/C itself is not on. Any ideas???
if you open the bottom panel of your furnace you will find the controll board there will be 4 wires coming back from the thermostat and 2 going to the a/c the 24 volt hot wire for the a/c will be hook to the yellow wire coming back from the thermostat take them off the board and wire nut them together this will do the trick in many cases
Aug 26, 2010 | Goodman CLQ36AR49 Air Conditioner
Had a Goodman heating unit installed in Oct. 2009. Recently tried to turn ac on .but no action. Installer returned and hooked up some wiring which got fan working but no cold air. The outside compressor...
It sounds like the outside condenser wires are still not hooked up correctly or there is a problem with the 24v electrical inside the unit. Describing what you have, I'm just banking on the connections. Now, if you have a heat pump system, there will be more wires and a little more difficult, but a normal split system will have two wires going from the furnace to the condenser. These two wires should be hooked to the Y(Yellow) terminal and the C(COM) terminal on the board inside the furnace. If it is a air handler unit, then it needs to be connected to the Blue and Yellow wires. The two outside condenser wires can be hooked up either way, it doesn't matter. I hope this is a simple fix for you and not something more. Good luck and I hope this helps.
Jul 04, 2010 | GE AJCQ08ACB Air Conditioner
WHERE THE CAPACITOR ON A GOODMAN 5 TON AC UNIT
Remove the cover where the power goes into the outside unit. In there should be the capacitor, circuit board, and contactor. There may be 2 capacitors or just one that works for the fan and compressor. If there is just 1 it will have 3 terminals and it is important to hook the wires back right so label them and write it down if you need to.
May 24, 2010 | Goodman CKL60AR60 Air Conditioner
Air conditioning problem. unit, compressor
Look inside your outdoor unit and find the compressor tag. It should have a model and serial # on it and a manufacturer. Then do a basic search on the net for the distributor of your compressor. However, most distributors will not sell direct to the public. You will most likely need to purchase one through a contractor. If you email me your compressor information I can help you locate and price one out.
Jun 01, 2009 | Goodman CKL36AR36 Air Conditioner
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
Ac unit central
Sorry, we don't have water cois in our area.
Aug 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman heat pump wiring
ok Let me see if this helps if not please comment back with the t-stat model and make as well. The Y terminal on the t-stat needs to be connected to the Y terminal on the heat pump board. If this does'nt fix it your thermostat may have something different going on so please send me the model and make of the t-stat. Also if you know does this unit have outside temperature sensing probes, and or an automatic defrost cycle?
Jul 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
213 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
