Question about Samsung RS2578BB Side by Side Refrigerator
Sumsung top fridge and bottom freezer
I really need some assistance. Our refrigerator starting blinking and i had called a repairman and he said that it was the motherboard so he changed the motherboard, the next day it started blinking and called him again and he said it was the fuses, changed the fuses, last for a week, then started blinking again, he changed the fuses again, and after a few days, it started blinking again, then he came again, and said he did not know why he keeps blowing fuses, and finally put on something with the fuses so that he would not blow, then the temperature or the display stayed the same, and then i noticed it wasn't blinking but it wasn't getting cold either. (talk about frustration), then i unplugged it and plugged it back, it came on, then in about a day it started blinking. so it is not fixed, and not working properly. If you can shed a light on these, that would be great. or suggest a repairman that handles samsung in the raleigh, nc areal .
thanks for your help
  • 619 Answers
Hi, The infeller struck to build of ice , causes the the beep sound ,defrost manually by two hours put electric fan to fast defrosting ,set rotate knob to defrost , you hear sound cracking of ice and smell burning that was could heating element for defrost if you hear sound like that in manual , later set automatic if timer will not turn you may replace timer .
Posted on Jan 22, 2008
Freezer working but why isn't fridge?
the damper motor will fail same as any other part .what number is the refrigerator part set on . normal is 4 or 5 , try increasing it . if it still doesn't work call a local repairman
Sep 17, 2015 | Bosch KGV33VW31G White 288 l Fridge...
Fridge not defrosting right water in bottom of freezer then turns to ice.
It sounds like the unit is defrosting, but the drain for the water from the melted ice is plugged. Check that before calling a repairman.
Sep 28, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
No ice coming out of my ice maker
did you turn the water on if so when you tightened the water line you might have tightened it to tight and crushed the water line
Apr 16, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Freezer not freezing
When was the last time you cleaned the condenser coils? They are either on the bottom of the unit (underneath) behind the grill, or on the back of the refrigerator. Use a refrigerator cleaning brush' (available at most home centers) to do the cleaning, or call an appliance service technician to accomplish this. After that, it could also be the compressor, or the condenser fan (bottom mounted coils), or a 'freon' leak. Call a repairman then!!
Dec 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
LG bottom freezer fridge - not cold enough!
this a prb wch u cant solve by u r self bcoz...this s a prb in u r jus call u r company engineer and they will help wont shell out more money for will be cheap of dont worry..its a ten minute job!!!
Jul 25, 2009 | Refrigerators
Fridge freezer problem
Your appliance needs to have the condenser area cleaned or it is low on freon. Call a repairman to look into it.
Nov 06, 2008 | Candy CPCA240FFK Bottom Freezer...
Sears Kenmore bottom freezer/refrig #68142model
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
My refrigerator is warm and ice build up is happening in the fridge
There is a timer that controls the refrigerator defrost cycles. This is located behind the kick panel at the bottom of the refrigerator. Remove the panel and look for a dial-like device toward the front. Try to manually turn the timer dial and listen for an audible click. No click, no defrost. Call a NEW repairman and have him check the defrost timer. Hope this helps.
Jul 27, 2007 | Samsung RB1955 Bottom Freezer Refrigerator
Samsung RS2578BB Side by Side Refrigerator Logo
329 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
