Question about Gigabyte GA-SINXP1394 Motherboard
I need a manual for a gigabyte GA SINXP1394 MOBO. I can't find one.
    Brigadier General:
  • 10,406 Answers
It took me less than one minute to browse the manufacturer's web-site:
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1618
to find "everything" about your "GA-SINXP1394(GA-8SQ800 Ultra2)" motherboard.
Posted on Dec 11, 2009
SOURCE:
GA-A7JM-UD2H network controller missing
Do you mean GA-A75M-UD2H. I can find no Gigabyte mobo with the designation you give. If the designation I have given should be correct you can download the appropriate driver from the following page by inputting the driver type you need and your OS in the dropdown menus
http://www.gigabyte.com/products/product-page.aspx?pid=3928#dl
Good luck
Feb 11, 2013 | Gigabyte GA-945GZM-S2 Motherboard
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
I have gigabyte ga-g41mt-s2p mobo does anyone have picture of correct cable connection layout, so I can check visually if I have connected the cables correctly
You can download "GA-G41MT-S2P" Manual and all the cable connections are in the Manual.
FYI
As for the Front Panel ATX casing cables connections, the "white" cables are the -ve polarity & the "coloured" cables are the +ve polarity.
Hope it helps.
Jun 26, 2011 | Gigabyte GAG41MTS2P motherboard
Does the GA-8I945P-G supports the Core2duo Processor?
No since this is a older mobo the manufactre only recomndes you use Pentium D, Pentium 4 HT, or Celeron D. many people have tried this and have had alot of problems and little success.
May 04, 2011 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
GA-MA785GM-US2H
You can find the manual here at Gigabyte. The appendix lists this information about beep codes:
Hope this helps you figure out what to do next. Thanks for using Fixya!
Feb 20, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
How much memory can I install using windows vista 32 on a gigabyte ga-8vm800m. I know on Xp is only 2 Gig
Usually the limit is 3.12GB in any 32-bit Windows OS. In-order to achieve full 4GB recognition you should install a 64-bit version. Here you can read some more information.
Feb 19, 2010 | Gigabyte Giga-Byte: GA-8VM800M-775...
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
Open Questions:
HUSHMAIL password reset phone HUSHMAIL password reset phone number +1800 828 0294 RAJAN number +1800 828 0294 RAJAN RAJAN Get HUSHMAIL 1800 828 0294 password reset phone number easy steps to forgot or change HUSHMAIL password reset via phone number #1-************ just follow some steps to recover HUSHMAIL password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure HUSHMAIL with HUSHMAIL or other microsoft account services. Their are many certified officer to suggest people that how to change or reset HUSHMAIL voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset HUSHMAIL password to reset or change it quickly, if you have any of them so contact to get well HUSHMAIL support form us. HUSHMAIL password reset not working HUSHMAIL password reset phone number HUSHMAIL password reset contact number HUSHMAIL password reset help HUSHMAIL password reset support HUSHMAIL password reset wont work HUSHMAIL password reset wont work HUSHMAIL password reset link HUSHMAIL password reset issues HUSHMAIL password reset usa HUSHMAIL password reset customer service. HUSHMAIL email account password reset ' free HUSHMAIL email password recovery ' cannot reset HUSHMAIL email password ' HUSHMAIL email password recovery ' HUSHMAIL email password recovery download ' HUSHMAIL email password recovery software ' free HUSHMAIL email password recovery. HUSHMAIL email password change, HUSHMAIL email hacked password changed, HUSHMAIL email hacked can't change password, change HUSHMAIL email password on iphone, change HUSHMAIL email password on ipad, change HUSHMAIL email password on android, HUSHMAIL email account hacked can't change password, how to change HUSHMAIL email password on droid, HUSHMAIL email password problems, HUSHMAIL email password not working, HUSHMAIL email account password reset. HUSHMAIL password reset phone number.
Apr 26, 2019 | Microsoft Computers & Internet
GMX password reset phone number +1800 828 0294 RAJAN RAJAN Get GMX 1800 828 0294 password reset phone number easy steps to forgot or change GMX password reset via phone number #1-************ just follow some steps to recover GMX password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure GMX with GMX or other microsoft account services. Their are many certified officer to suggest people that how to change or reset GMX voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset GMX password to reset or change it quickly, if you have any of them so contact to get well GMX support form us. GMX password reset not working GMX password reset phone number GMX password reset contact number GMX password reset help GMX password reset support GMX password reset wont work GMX password reset wont work GMX password reset link GMX password reset issues GMX password reset usa GMX password reset customer service. GMX email account password reset ' free GMX email password recovery ' cannot reset GMX email password ' GMX email password recovery ' GMX email password recovery download ' GMX email password recovery software ' free GMX email password recovery. GMX email password change, GMX email hacked password changed, GMX email hacked can't change password, change GMX email password on iphone, change GMX email password on ipad, change GMX email password on android, GMX email account hacked can't change password, how to change GMX email password on droid, GMX email password problems, GMX email password not working, GMX email account password reset. GMX password reset phone number.
See all Gigabyte GA-SINXP1394 Motherboard Questions
Gigabyte GA-SINXP1394 Motherboard Logo
110 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Thomas F. Schneider
robert roberts
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
