Question about Sony Xplod XM-554ZR Car Audio Amplifier
I have a sony explod stereo and it works fine. Ecept that every once and awhile it shorts out and stops playing for a couple seconds. When this happens all of the stations i had saved and the clock are all reset. What do i do? Is it the Power or something else?
    Scholar:
  • 84 Answers
Could be power, could be ground, do you have a factory amplifier aswell as an aftermarket one in your vehicle.. If so if you have the 3 remote wires spliced together to kick on your factory amp you can have problems with this. Basically having more than 1 amp wired in series together can do this... there are many factors to this but first check your ground on the headunit and make sure it's makin a good chasis ground..
Posted on Dec 13, 2009
SOURCE:
Sony car stereo, cd working but not radio
I'm an MESA certified installation tech for car audio, Pull your head unit out and make sure that your antenna cable is properly connected! If that's not it let me know!
Aug 26, 2012 | Car Audio & Video
My Sony PS3 is the orginal 60 GB unit and worked fine for quite a few years until the icon stopped appearing. This meant I could play blue ray, CD, DVDs. I had no problem playing a game that was on the...
You can try to do a system recovery on your PS3. this will set your PS3 back to factory settings as the settings may have been changed during the use. Here is the process in which you can do a system recovery.'
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
I think you choose option 3 and then repeat and choose option 4. Once you are done with this, try out your PS3.
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
My Pioneer car stereo stops all audio signal after a couple of minutes regardless whether i'm playing a CD or the radio, but the stereo stays on. and the CD seconds and minutes still count, do you know why...
Check your connections to your speakers and amp and look for loose wires touching metal. I believe your stereo is fine, this has something to do with your speakers and the speaker wire
Jun 07, 2010 | Pioneer DEH-P6400 CD Player
My water heater cuts of after 30 seconds and shows C2, 11 code
sounds like your gas lines are too small or not enough pressure... or you may have to clean the rods
Jan 13, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
I have a projector (SONY VPL-ES1) and the bulb stopped working. Took the bulb out, and not sure if it's blown or not. I checked online, to see if anyone else had similar problems, and sure enough they...
usually the projector powers and cools down. if you restart it it will open the cover, not projecting anything and after 10 seconds it will close again. this happens if the lamp is shortly before the end of the measured lifetime (no fixed hours) to protect the projector. usually if you take it out once or twice it will work for 1 or 2 more times but the bulb is very likely to explode (not destroying the projector but not good anyways)
Dec 30, 2008 | Sony VPL-ES1 Multimedia Projector
Sony slv 715ub no stereo sound on tape playback
Hi, i have a Panasonic dmr-es30veb DVD ram recorder/VCR and i cant record one channel while watching another, as you can tell i am not at all technically minded and if you can help i would be grateful many thanks Eileen.
May 13, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony car stereo CD load fault
The player probably has failed.
Jun 01, 2017 | Car Audio & Video
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
Sony Projection TV KP-43HT20
call tech ..suggest solder conn in or around tuner..
Nov 26, 2007 | Sony KP-43HT20 43" Rear Projection...
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
