Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My liftmaster garage door will not close..I have changed the main gear in the machine.. but I have also tried to make it shut without the door attached and it still will not go down. it goes about a foot then stops. It will go down if i hold the garage door open down the whole time its closing... think you can help?
    President:
  • 3,197 Answers
Make sure you put the black cup back onthe end of the motor shaft and that it is pressed all the way on.Make sure the RPM sensor is plugged in. If neither of these are theissue, then you probably did not have the motor shaft pushed all theway back when you tightened the coupler after replacing the wormgear. Loosen that coupler up and from the front of the motor(opposite end in which the coupler is on) push the shaft back as faras it will go. Hold it there while you tighten the coupler back upand then try it.
Posted on Dec 11, 2009
Door shuts but opens without touch button , just fitted new worm gear this is a chamberlain model41a2817
If the unit was working before replacement and you lowered opener power head and removed wiring ensure that the safety sensors are wired correctly.LIFTMASTER Garage Door Openers 41D3452 Limit Switch AssemblyPerhaps your limit switches may need to reset, (located close to gear assembly) also the closing force may need to be adjusted. Good luck
Aug 18, 2017 | Building Materials
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
How much is gear kit for 1/2 #41A2817?
Gear kits can be purchased for chain drive machines from any of these 3 brand names ...Liftmaster/sears craftsman /chamberlain / All 3 of these brand names are manufactured by Liftmaster the worlds largest maker of garage door openers and related parts ! You can purchase a gear kit on ebay for around $30 or less depending on the seller ! If you go to garage door parts sites it will be slightly higher so your best bet is EBAY , The gear kit only requires the main gear and sprocket housing that attaches with 3 screws , just remember after the gear is installed that you run the motor co that the trolley starts in the door down position otherwise you risk having the trolley smack into the opener , this is crucial for any travel adjustments that are made later! Hope this helps you ,sincerely Glenn
Feb 04, 2015 | liftmaster Garage Door 1/2 Hp
41a4315 7a parts
The gears are all the same with the exception of the belt drive units that have a different top sprocket , you can find the part # on the internet simply by putting in the model # of your opener and identifying whether you have a belt drive or chain drive machine , you can also find the part on Ebay by putting sears/liftmaster or chamberlain sprocket gear assembly in the description ....All 3 of those models are made by Liftmaster being the main Brand ! Liftmaster manufactures the sears craftsmen for Sears and also goes under the chamberlain brand name that k mart and Home depot and Lowes sells ! Liftmaster is the worlds largest manufacturer of garage door openers and all 3 machines are interchangeable with their parts ! Hope this helps you Sincerely Glenn
Sep 01, 2014 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster Garage Door opener will not open or close without stopping in the middle of the cycle.
Release the door from the opener and operate by hand to check for binding of the door in the area it stops. Remove the cover from the motor unit and check the drive gear. This is a white nylon gear just in front of the motor and it will be obvious if it is going bad.
Aug 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage door is closed and wont open, it beeps and all the LED's light up. there is no obstructions. I think that it keeps to try and shut but already is. Its a securalift GDO - 7 V1
Tries changes batteries in the remote,unplug the main operation motor,replug it,see if it reset it self.This a temp.fix,call the mamfucture for repair or replacement.
Oct 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Check your door springs. One of them is most likely broken and is what caused your drive gear to strip in the beginning.
Jun 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Grage door reverces and goes back up after touching the ground
try adjusting the close shut off switch.(limiting switch) It sounds like when the door shuts, it has too much pressure. The sensor picks this up and reverses the door.This is a saftey feature. It just needs adjusting
Mar 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door won't shut after changing gears
if you changed gears, you may have chain out of sync. read instructions with gear kit on how to sync chain.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
