Could someone please help us? There are thousands of codes to unlock dvd-players and make them region free, but I am not able to find the code for our LG DVC5930-DVD-player. We sincerely hope someone can help us. Yours faithfully, Jeroen Reichart
You have probably used up all your region changes. These are limited for copyright reasons.
Download Anydvd from Slysoft.com
This will run your dvds as "region free"
Burn them with Dvdshrink
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player; 2. Make sure the TV is set to the correct input for the DVD player; 3. Remove any disc from the DVD player and close the disc tray; 4. Press the "SETUP" button on the DVD player remote control; 5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE"; 6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
try to unlock your dvd player to play all free region. what you need is the code to unlock and a remote control to enter the into menu/programming mode. please specify model # of your dvd player when you look for the unlock key.
The region code can only be changed 4 times and it locks on the 4th change. There may be a firmware upgrade that make your DVD region free, but if you make a mistake or install the wrong firmware upgrade then the DVD will be a piece of junk. You will need to Google search for DVD firmware upgrades for your model DVD. The best way to view DVDs from other regions is to install a piece of software that defeats the region code. I use a program called DVD-RegionFree from www.dvdidle.com There are possibly other programs available, again Google search for them.
