Question about Nintendo Wii Console
CD will not load. It will insert spin and pop
CD will not load. It will insert spin and pop back out.
  • 311 Answers
Hey
in this case you can do thing and check for the drivers
do right click on my computer icon and then got properties- hardware- device manager
then go in DVD and expand it and highlight each adaptor from there and uninsatll it , then do a right click on
DVD and the scan for hardware changes if that works than it good other you need to look for the drivers for your DVD rom
Posted on Dec 11, 2009
SOURCE:
Cd wont play it picks up an goes around but wont play need to know what to do
It sounds that the optical pickup unit to your player is faulty. Open the top cover of the player, power it ON and insert a CD in to. Check whether the inserted CD loads well into the mechanism and spins. If do not spins, sled motor is faulty. If it spins, optical pickup unit should be replaced.
Apr 23, 2012 | Durabrand CD2160 Shelf System
With disk in, says no disk
Open up the cover of the dvd deck hook it up to ac outlet power up and and insert the cd, have a close look as the cd is loading. If your CD spin and the there is a red light coming or flickering from the back of the CD and the spins that means it needs CRC cleaner.
IF it spins and stop after 5 secs then it the motor that needed to changed.
If no light coming from the back of the CD then it a laser broblem.
Never run the DVD with no CD on as the light coming from the laser can cause blindness.
THKS
Jul 22, 2009 | Televison & Video
The spin motor is going but its not spinning i believe the belt popped off how do i open it up to pop it back on
For the FAV6800/FAV9800AW download the service manual;
5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the Service Manual
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
As mentioned on page 47 of the SM Roll Drive Belt on the Pulley. (Do not loosen motor bolts). If the belt is broken see Sears Parts Direct for a belt P/N.
Jul 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dell XPS 1300 Cd rom problem
This is a CD drive mechanical problem. All CD/DVD drives have built in error checking for mechanical failures. When you insert the CD/DVD, it tries to grab and seat the disc, then attempts to spin it up and then read it. If the grab and seat function fails for any reason, the drive will eject the tray so you can try again. You should contact Dell support and get the drive replaced. Has the drive ever worked? or did it just stop working one day?
Nov 02, 2008 | Dell Inspiron 9100 XPS Latitude D400...
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
Loading error
dvd error disic after playing ten min, the pitcher crash
May 04, 2007 | Alpine IVA-D300 Car DVD Player
CDPops Out *EDITED*
Does it pop out immediately? If not, listen carefully to the drive after you insert the disc. Can you hear the disc spinning? Any activity from the laser? If the disc is not spinning but you can hear the faint whirring and clicking of the laser transport, it could be that the laser itself has failed - it's the laser that detects if a CD is present. If it doesn't detect anything (due to being knackered!), the disc will not spin and will eject.
Oct 31, 2006 | Nu Mark Numark Cdx Table Top CD Player CD...
Nintendo Wii Console Logo
54 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
