Question about Hoover Commercial C1403 Bagged Upright Vacuum
The bag was full, it has been changed - still no power when plugged in
  • 175 Answers
It sounds like you have carpet fibers and lint that are stuck in the motor carbon brushes. That is common on this machine. You will have to take the motor out and have it thoroughly blown out will an air compressor.
Posted on Dec 11, 2009
No power but lights flash
Is there a reset switch. Most vacuums have one some where near the bottom brush, to protect the vacuum from overload. If the vacuum tripped, the vacuum will not work until you've pressed the reset switch. If you can't find one, pls check manual.
Mar 04, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Not powering on when plugged into wall
Change the bag. It has an automatic bag full shut off switch.
Apr 15, 2011 | Proteam ProForce® 1500XP Bagged Vacuum
I have a Bissell DigiPro canister vacuum and it has no suction. It is only 4 months old. What would the problem be?
Probably a clog in the hose. Disconnect the hose at both ends. Drop a coin in one end and allow it to fall through and out the other end. If it doesn't, the hose is blocked. Plug the end of the hose into the blower of the vacuum and turn it on. Make sure the other end of the hose is in a plastic bag. This should clear the clog.
Also, check the power nozzle behind the brush. Something may have gotten caught in the elbow near where the wand plugs in.
A full bag will also cause this, or if there's a lot of fine dust in your area, clogged pores in the bag will act the same as a full bag.
Jan 20, 2011 | Bissell 6900 DigiPro Bagged Canister...
3 lights show up on the top of my vacuum and the center one I don't know what it stands for. Plus, the vacuum seems to be getting too hot.
The one that looks like a cord plug lights up when the vacuum is plugged in and indicates it's getting power.
The one that looks like a thermometer lights up when the vacuum is overheating, and indicates there's probably a clog in the hose or power nozzle behind the brush.
The next one indicates there is no bag in the vacuum. Machine will not run.
The last one indicates the bag is full and needs to be changed. A full bag or clogged pores will result in overheating, however the vacuum automatically turns off when this happens to protect the motor.
It sounds like you need to replace the bag. If you still have problems, it's probably due to an internal part called a control valve assembly. That is an in shop repair, and the vacuum needs to be taken to an authorized Aerus Electrolux store for service. This is most often due to "made to fit" bags being used instead of "genuine" bags. In this case the motor and interior of the machine need to be cleaned as well. Dirt, even fine dust, in the motor will shorten the life of the motor dramatically.
Dec 02, 2010 | Electrolux Epic 6500 Vacuum
My dirt devil just shut off in the middle of use, the bag was very full but it will not kick back on. Have tried every working plug in the house?
Does your machine have a switch that turns it off when the bag is full? Have you changed the bag?
Please try this solution ...
Thanks for your interest in FixYa.com
May 15, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
How to reset?
The button I think you are talking about is the bag switch. It is located in the bottom right corner where you put the bag. If the bag does not cover it, the machine will not run.
Also, when the machine cuts off when the bag is full, you have to push the power switch off and back on to reset the full bag switch located in the switch control housing inside the machine.
Mar 13, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Hoover Commercial C1403 Bagged Upright Vacuum Logo
41 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
