Question about HP Media Center m1270n (PP132AA#ABA) PC Desktop
Power Supply for HP Media Center m1270 PC
I bought the HP Media Center m1270 desktop 5 years ago. The power supply is not working no more. I want to know which brand and model of the power supply I should buy to replace my old one.
Thanks,
Sophie
    Sergeant:
    Champion:
  • 240 Answers
Are you sure it's the power supply?
Most modern power supply units are of the ATX type. Brand should not matter. Your PC used a 300 watt power supply when new. You can purchase a power supply with more output (watts) if you like, but not less. You will have to purchase from a computer specialty store most likely - take the dead one in and compare it side by side with the new one before buying.
Posted on Dec 11, 2009
Hp pc m7360n no power
after doing this if the power supply fan turns on means your power supply if working fine and if it doesnt work there is problem with power supply.
if the fan turns on and still there is no power there is problem with mother board
May 16, 2014 | HP Pavilion Media Center TV m7360n...
My hp media center pc worked fine untill about two months ago when it just shut off on me after a couple hours of use. The power button was flashing blue and orange and the only way to turn it back on was...
This could be a heat issue. If the PC is on the floor, it will draw large amounts of dust and dirt into the machine via cooling fans. Check this link to reduce heat inside your case and on individual components.
Look at the rear of the PC - near where the power cord connects to the power supply. Locate the LED lamp and compare to this link for HP's document to assist troubleshooting the power supply.
Hope fully, one of these options will be a solution for your problem. Good luck!
Jan 11, 2011 | HP Media Center m1270n (PP132AA#ABA) PC...
HP m7250n shuts down unexpectedly.
your power supply is faulty you will need to replace it. If you recently installed a new hardware it could be you don't have enough power to, either upgrade you power supply or remove the hardware.
Feb 27, 2010 | HP Media Center m7250n (ED842AA) PC...
I can not start my PC. It does have a green
Sounds like a defective power supply. Improper power coming from the supply will cause a unit to fail boot. Power supplies are about 40 bucks.
Oct 01, 2009 | HP Pavilion Media Center a1330n - AMD...
HP Media Center does not power on
Sounds like your power supply has took a dive.
You can replace it yourself for really cheap $20-$50 or have a local repair shop or someone from craigslist for about $60-100.
It's really just four screws to remove the power supply and then you just put all the power connectors back. It's NOT hard if you just take your time and pay attention to what you are doing.
Best of luck!
Jun 13, 2009 | HP Media Center m7250n (ED842AA) PC...
Need to replace the power supply on a m370n hp pavillon
A normal ATX power supply will work for your system. When purchasing make sure it is an ATX style psu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | HP Media Center M370N (DM163A#ABA) PC...
Hp media center power
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
Jul 11, 2008 | HP Media Center m7060n PC Desktop
HP Media Center PC m7250n will not power up
hold the start button in and check the back of the case to see if the power supply fan turns while the power button is depressed. If it turns while the button is pushed, but then stops when you let off the button, then the power supply is probably bad and needs replacing.
Jun 01, 2008 | HP Media Center m7250n (ED842AA) PC...
HP Media Center m1270n (PP132AA#ABA) PC Desktop Logo
250 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
