Question about Food Mixers
Doesnt always switch gears & clicking noise
My 5 qt. kitchen aid mixer doesnt always switch gears. Consequently when I need it most, it hasnt got the strength to do things like whip egg whites ar knead bread dough. There is also a clicking noise that comes and goes. Any sugesstions?
  • 235 Answers
Hi LEEMOSHER. You don’t indicate your specific KA mixer model, which limits possible solutions options, but I’ll give it the old college try!
When you say ‘switch gears’ I assume what you really are referring to is changing the speed setting. There is only one set of gears, but 10 speed settings, which make the beater turn faster. From your description of the symptoms, I suspect your mixer’s speed control board is having issues and should probably be replaced. Since I don’t know you model number, I can only provide you general instructions.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number and select a file listed under Parts List. Some models will have multiple files. Download one and check to ensure it matches your mixer model. If it doesn’t match, continue to look at other manuals until you find the correct manual that does match.
Depending on your model, locate the Governor Assembly and Control Plate Assembly on the pages titled: Motor Control Parts, or Control Assembly on pages titled: Case, Gearing and Planetary Unit. The illustrations provide an exploded view for the disassembly and reassembly of your mixer’s components, along with all the parts.
First inspect around the controller assembly to ensure all the wire connections are OK. It's possible a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board which was not meant to be 'home fixed', and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Without a clearer description of your clicking noise; i.e., when it occurs, where is the sound coming from, I’m at a loss to explain. However while your mixer is apart would be an ideal opportunity to check for any other unseemly wear and tear on the gears, etc., and you might discover something out of place that is causing the clicking. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
Posted on Dec 11, 2009
SOURCE:
Kitchen aid mixer kg25hoxer repair manual
Request the repair manual directly from KitchenAid.
Feb 26, 2018 | Food Mixers
My Kitchen aid Ksm90 mixer got a little noisy, then it just wouldn't even turn on. What could be wrong with it?
You have possibly blown the fuse gear. Need a bit more info on the noise. If you turn it on slow and help the planetary does it try go get itself going?
Jan 16, 2015 | KitchenAid Kitchen Aid Ultra Power Tilt...
I own the 6 QT Stand mixer. Is there a Is there a 4 or 5 qt bowl that works with this mixer?
Kitchenaid does not make a 4 or 5 quart bowl that would fit your 6 quart mixer, but other 3rd party companies do!
You may be in luck.
I haven't seen this bowl in person, but it apparently will fit your 6qt mixer. Here is a link to a page selling the mentioned attachment. It comes in a set, with appropriate wire-whip attachments:
http://www.chefscatalog.com/product/25686-kitchenaid-3qt-stainless-bowl-and-whip-set.aspx
Jan 13, 2015 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Where can I get the grease for my Kitchen aid stand mixer?
The grease is food grade grease and Kitchen Aid supply it as a spare part so depending on where you live either from themselves or an Authorised Service Agent. If you are in New Zealand then I can supply.
Jan 01, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Hello. I have a Kitchen Aid mixer made by Hobart between 1975 and 1978. It is a stand mixer with a 5-quart bowl that lifts and locks into place. While it was kneading a bread dough, the motor...
Hello Suzann,
I understand that you are having a problem with your Kitchen Aid 5 Quart mixer. It sounds like you have stripped the gears or the worm gear out. Although, it may not be an expensive parts repair it is not an easy task to complete if you are not mechanical enclined. There are many different little gears in these units.
My suggestion would be to take it a local appliance repair shop that works on mixers. If you can tell me the city that you live in I would be more than happy to give you the location of one or two repair shops. As the unit is so old you want to invest in a new unit and keep that one as a reminder of how long Kitchen Aid has been around.
Thank you for choosing FIxYa.com
Justin Burnett
Mar 16, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
KITCHEN AID MIXER K5SS has a banging noise when turned on how would I find out how to fix it ?
You will need to open it up and inspect the brushes carefully. Look for a little copper wire, this wire needs to be firmly attached to both the brush and the little disc at the other end of the spring. Clean the brush out with a can of electric cleaner to free any dirt that has built up around the gears.
Jan 04, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid 6 qt mixer repair
A small screwdriver or needle nose pliers will work to remove the cir-clips that hold on the shaft.
Apr 24, 2010 | KitchenAid KP2671 Professional 6 Series...
Food Mixers Logo
293 people viewed this question
Top Food Mixers Experts
Bruce Showalter
Marvin
Marvin
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
