Question about Gaggia Synchrony 90101 Espresso Machine
Frother doesn't steam strong enough
Frother steams, but not strong enough.
    President:
  • 1,618 Answers
Frother might be blocked, descale unit or use a paperclip to clear the end of the frother, or depending on the model there is a small teflon piece in the top end of the frother, remove that and discard.
Posted on Dec 14, 2009
More detail to my question on mal function of milk frother. Coffee making function is working well and I have descaled as per instructions. When I try to use the steam arm there is a pumping sound but...
This might not be the problem , but sometimes , not cleaning milk frother tip properly , the tip gets closed with dry milk. use a needle and push it in the frother tip and see if there is a restriction. hope this helps.
Mar 22, 2015 | DeLonghi Pump Espresso Maker
Your question: "I have a Delonghi magnifica 3300 that is 7 yrs old. It doesn't heat the coffee very good and the steam frother doesn't work well either. I have always used filtered water and descale i
If heater not working properly ,but still working the heat transfer poor ,probably need to disassemble and actually manually clean heater unit with wire brush till really clean,otherwise replace heater unit as heaters are usually fully sealed. get on line and search for Delonghi magnifica 3300 (parts diagram , replacement parts,parts). then you will have part no and hopefully someone who can supply parts.As for frother if water not heating to enough to make hot coffee the not heating enough to make steam either so frother does not work,if blocked then need to clean out frother tube.
Sep 07, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
No steam from Magimix expresso
Has anyone got a solution to no steam from milk frother please
Dec 12, 2011 | Magimix L'Expresso Espresso Machine
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
How do you clean the frother on the ESP8XL machine?
1. Remove the froth enhancer and rinse under warm tap water. 2.. Wipe the steam wand with a damp cloth. 3. Briefly set the Selector Control to the ‘STEAM’ position to clear any remaining milk from the steam wand. If that doesn't work, remove any rubber parts. Place the metal frother tube in a pot of water with a bit of ammonia or vinegar in it. Heat the water to boiling, then let it simmer awhile.
Nov 08, 2009 | Breville ESP8XL Espresso Machine
Frother not working
The frother does not have a vacuum, it uses venturi pressure to draw up milk through a venturi at the top of the steam feed. The milk side is clogged from not cleaning enough. soak in boiling water for a few minutes and try to run it in steam mode for a while... if that doesnt work, a light lye solution will dissolve the milk residue clogging it. neutralize the lye with vinegar drawn through after the clog is gone.
(lye will dissolve you as well as milk... use gloves and don't put your face near it while it's working.)
Apr 19, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Nov 20, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Gaggia Synchrony 90101 Espresso Machine Logo
283 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
