Question about O2 Xda Orbit Smartphone
In the middle of a telephone call, the phone switches off with a full or partial battery.
  • clive_lawn Dec 11, 2009
    Have done the hard reset, but the problem still persists. Call connected for a few minutes then the phones switches off.
    Having hard reset the phone I have changed n othing other than times has now decreased before switch off.
    President:
  • O2 Master
  • 2,923 Answers
The problem with this phone could be the battery or the firmware.
There could be a possibility that the battery is not holding the charge properly. When idle, the battery shows fully or partially charged but once you make a call, the battery could not provide enough power for the phone, that is why it's shutting off.
You may try using a known working battery (it should be for this phone) that you could borrow in some repair centers for testing. If the same problem happens, then the problem is not the battery, it's the firmware of the phone.
To re-flash the firmware, you need to contact the manufacturer and have them to reload or upgrade the firmware of the phone. And that should work correctly.
This problem happened to me before.
Thank you!
Posted on Dec 12, 2009
  • 3,230 Answers
Well first of all you can try to reset your phone, please follow the below steps to do a hard reset -
Press both soft keys and insert stylus into soft reset button and press.
Release the soft reset button and keep pressing the soft keys.
When the "This operation will delete all your personal data, to manufacturer default" appears on screen.
Press Green call button to restore manufacturer default, or press other keys to cancel.
The bootloader is invoked by pressing down the Power and Voicedialer buttons simultaneously, and using the stylus at the same time to press the RESET button at the left side. Continue pressing the two buttons for a few seconds after pressing and releasing the reset button until the bootloader screen appears.
note. save our all data before you do a hard reset because reseting delete your data.
please post comments if further you have the same problem ....
Good Luck!!
Thanks
Posted on Dec 11, 2009
How do I program the T7208 telephone to display incoming telephone numbers?
I managed to find the manual, but it does not say a thing about this. I think your provider has to give you the information, with the incoming call. When he switched that information of, your phone can't display it. Sometimes the providers charge you extra for that service. If, on the same extension, another phone did display the number, perhaps hetre is a way to switch it on, but I could not find it.
The link is to the manual.
http://ipf.msu.edu/_files/pdfs/user-guides/norstar-t7208.pdf
Sep 30, 2014 | Nortel Networks T7208 Telephone
Tip
How To Fix Your HP Fax Phone Off Hook
<ol> <li>If you don't know your product number, <a href="http://h20270.www2.hp.com/ediags/gmn2/welcome.aspx?lc=en&cc=us">click here</a> to automatically detect it.</li> <li>Manually download your drivers by <a href="http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us&lang=en&softwareitem=oj-40521-2&os=228">clicking here</a>. Enter your Printer Model Number, e.g. Deskjet D2680</li> <li>Unplug the power cord from the back of the printer and from the wall outlet. Reconnect the power cord to the wall outlet, but don't connect the power to the printer just yet.</li> <li>Perform a partial reset by disconnecting the power cord from the wall. Then, hold the # and 3 while reconnecting the power cord. Release the buttons once the cord is plugged in. When you release both buttons, the issue should be resolved.</li> <li>Perform a semi-full reset if the partial reset did not work by pressing and holding # and 6 while reconnecting the power cord to the printer and hold for 1 min after plugging in the power cord. When you release both buttons, the issue should be resolved.</li> <li>Verify that the phone cables are properly inserted into the wall jack and the back of the printer if you are receiving a "Phone off the hook" error message.</li> <li>A Phone Off Hook message indicates that the telephone line is open. This message would be expected in the following situations:</li></ol> <ul> <li>A modem on the phone line is accessing the Internet. When the other device is no longer using the phone line, the display should revert to the normal message.</li> <li>A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.</li> <li>A credit card machine is using the phone line.</li> <li>Another electronic device is using the phone line.</li> <li>Telephone Answering Machine using the phone line</li> <li>The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.</li></ul>Check this website for further help from HP: <a href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00322712&cc=us&lc=en&dlc=en&product=441125">http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00322712&cc=us&lc=en&dlc=en&product=441125</a>
on Feb 22, 2011 | Office Equipment & Supplies
Tip
Laptop battery systems allow you to contact a user that may be walking...
laptop battery systems allow you to contact a user that may be walking around.dell latitude c600 battery Each system has a base unit which enables you to page the handset of a user, so long as they are in range. You can then speak to the user through the intercom facility. Some systems allow you to use another handset as the intercom instead of the base station.
http://profiles.yahoo.com/blog/
How you ask? With Internet phone service, or more specifically, broadband phone.dell kd476 battery Don’t be confused by the name. A common misconception is that you’ll have to use, or have your computer running to use broadband phone service. Not true my friend! Your computer can be completely shut down, and you don’t need it at all to use your telephone with broadband phone service. No more headphones, no more typing in phone numbers, just use any touch tone telephone to make and receive phone calls the same way you always have.
How is this possible? You may be shocked by this but, you’re essentially cutting out the middle man to transfer your incoming and outbound phone calls with a tiny black box that does the same job your traditional phone company has always charged you for. It’s called a broadband phone adapter. The broadband phone adapter uses your Internet connection, (not your computer) to send your calls out to the same grid your traditional phone company uses to transfer phone calls! By cutting out the middle man, (your phone company) you’re also cutting out a huge chunk of your phone bill.
There is growing consensus that laptop battery antennas may be harmful to humans due to the huge volume of electromagnetic waves that get concentrated around it during the receipt and placing of calls. This danger is even further aggravated by cellular manufacturers who place the internal antennas close to the earpiece.
on Mar 31, 2010 | Computers & Internet
All lights blinking
On the left side there is a slide switch that is in the test position. Return it to the middle position and it will clear your problem.
Jan 17, 2014 | Avaya AT&T Merlin BIS 34D Telephone
New battery runs down in about six hours ... why?
Make sure that you're getting a full charge on your battery, and NOT just a partial charge!... If you are getting a full charge, you might want to try a different battery!... You might have ended up buying a defective battery!...
If neither one of these is a viable option, maybe you're using your "speaker phone" option more than you realize!... The V9's are notorious for having a short talk-time, especially when in "speaker phone" mode!
Feb 23, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
Handset(receiver) Lucent Corded Phone Model932 blanks out during phone call
After 10 years of service, and allowing for the fact that Lucent is no longer around, it may be best to simply replace it.
Dec 17, 2017 | Lands Phones
How to find unknown incaming calling location
I can think of 2 possible causes:
1) The call originated from an International location and you are seeing a partial originating telephone number.
2) The originating caller has a type of telephone service that allows their telephone system to generate the digits that appear on Caller ID displays. Their telephone is creating that strange looking telephone number.
My guess is that the first cause is the correct one.
You can try googling the numbers on the display to see if anyone else has had this happen to them. Your telephone service provider could run a trace on the call, but that would require going through a legal process that, if this is a one time event, would really not be worth the hassle.
Dec 24, 2008 | Uniden Cordless Phone
Unparking calls feature does not work
Press the hook-switch and release it immediately; this is what the 'flash' button simulates doing. In other words hang your phone up for half a second or less and you have sent a 'flash' signal. This will work with any analog phone. If you have ever used traditional call waiting from your home telephone it is exactly the same.
Jul 31, 2008 | TalkSwitch CT.TS001.124001.US...
How do you program Auto Dials for BIS-34D?
We have these exact phones in our Central Control Room. We do not have instruction manuals for them either and they are discontinued. However, I figured out how to program external phone numbers into the speed dialer.
First, put the switch on the left-hand side of the phone (near the handset) to the "P" position. This will make all the lights and ringer go off. You are now in program mode. Next, press a button on the right-hand side of the phone that you would like to program a number to (say the top, right button). Press the button and it should say "blank." Then, go ahead and enter the telephone number that you want for that button. You should see the number appear in the digital display up top. After you've done this, press the top, right button again and this programs the number into that particular button!
Repeat the above steps for multiple auto-dialers going on down the column.
I hope this helps!
Dec 13, 2007 | Avaya AT&T Merlin BIS 34D Telephone
O2 Xda Orbit Smartphone Logo
37 people viewed this question
Top O2 Computers & Internet Experts
xxxxxx xxx
Hjalmer Lamminen
Hjalmer Lamminen
moha150583
Level 1 Expert
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
