Question about Nokia 5800 XpressMusic Smartphone
Sir, My Phone start up Failed Contact the Retailer.
SOURCE:
SOURCE: 3230 start up failed
u need to format it manually by pressing power on, call options, 3 & * simultainously tested and proven!
Posted on Jun 09, 2008
dofsqaa
  • 169 Answers
SOURCE: 7610 Gsm start up failed,contact retailer.
System might be damanged,
You can hard reset the phone (Factory Settings)
This will reinstall the operating system inside the phone back to how it first was.
(internal memory gets formatted then the rom reloads the os back)
(Solves all kinds of problems.)
Switch the phone "OFF"
Hold "3" (button) + "Green Call" (button) + "*" (star button)
Switch the phone "ON" while holding the above three buttons.
Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory. including phonebook numbers (if not stored on SIM card).
Try to make backups first.
You have been "Warned".
Best of Luck.
Posted on Jun 21, 2008
coldhourz
  • 199 Answers
SOURCE: Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Posted on Aug 28, 2008
hornbillexp
  • 50 Answers
SOURCE: mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
Posted on Jan 15, 2009
SOURCE: Nokia 6680, Phone start-up failed. Contact the retailer.
nokia 6300 phone start-up failed
Posted on Jul 24, 2010
Hai sir my phone start up failed contact retailer can i have the solution to this soon as you get this please
you mean mobile getting start but not fully load or dead fully which one you have
May 17, 2012 | Nokia C5 Cell Phone
Phone start up failed contact the retailer
Usually can't solve this issue with home remedy. Attempt to call service provider or do as it says...contact retailer.
Apr 14, 2010 | Nokia 6600
7610 start-up filed
software fault go nokia care & flash ur phone 101% ok
Aug 21, 2009 | Nokia 7610
Phone start-up failed. contact the retailer
phone start-up failed contact the retailer
Jun 23, 2009 | Nokia N76 Cellular Phone
Phone start failed contact retailer
sir i have c7 nokia when it on a message shown. phone start-up failed.contact the retailer.plese help me what i do
Apr 24, 2009 | Nokia 6681 Cellular Phone
Need to formatting nokia 6260 mobile
Hello sir,
I got the same startup failed problem. Did u get any solution. Please let me know how to resolve this issue. my id is surenar.malreddy@gmail.com
Thanks.
Mar 23, 2009 | Nokia 6260 Cellular Phone
Nokia n72 phone startup failed contact retailer
FORMAT YOUR HANDPHONE. TURN OFF YOU HANDPHONE, THEN PRESS CALL, 3, AND STAR THEN PRESS ON KEY. YOUR HANDPHONE WILL BE FULL FORMATTING.
Jan 22, 2009 | Nokia N72 Cellular Phone
Mobile not open "phone start-up failed. contact the retailer"
press and hold SEND key+* key+2 key when you switch on the phone
Jan 18, 2009 | Nokia 6630 Handheld
Nokia 5800 XpressMusic Smartphone Logo
132 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
