Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
I have a Gu2500XTPQ1. It will not start a new wash cycle.
I have a Gu2500XTPQ1 Quiet Partner 3. It will not start a new wash cycle. No matter what cycle I choose, as soon as I press start, it instantly lights up the "clean" status and thinks it is finished even though it never started. I have already tried turning off and on the power. Is there any reset procedure I can try? Is this a symptom of another known problem, perhaps a safety feature indicating a failure in another component?
  • 5,911 Answers
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
If you have any questions, please let me know. I hope this helps you solve your problem.
Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. The tech sheet should explain the procedures in detail. If it is not located behind the lower toe panel, or affixed somewhere under the dishwasher, I have also found them located inside the inner door panel. Let me know if you still need assistance.
Posted on Dec 11, 2009
SOURCE:
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
413 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
