Question about NAD C740 Receiver
C740 will not power up..
At first it was intermittent and now it is completely dead.
I took the unit to my repairer who said the faulty part was 'Oscillator XTAL 701' which apparently is no longer available.. A big bit disappointing.
Can anybody offer any suggestions on where I might be able to source this part or any alternatives or even any hacks to get it working with reduced functionality (if possible).
Portable AC is completely dead
Technicians trick. Power goes into board but not out.. Bad board. Replace it. The only repair on a PC board should be done but someone who does it everyday. I've made that mistake before.
Jul 02, 2013 | Whirlpool ACP102PS Portable Air...
Hp 4510s not charging
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 01, 2012 | HEWLETT-PACKARD HP ProBook 4510s Notebook
Dead toshiba satellite laptop
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 01, 2012 | Toshiba Sattelite A105-S2071 Notebook
Pantech c740 unlock code Imei # 011917001521014
Get the unlocking service from your network provider or you may get it from www.mobile-unlocker.com . After getting the code, you may follow the instructions here,
1. Switch ON your Pantech C740 with its ORIGINAL SIM card.
2. Type *#865625#.
3. A SIM Unlock Menu will appear, press OK.
4. Enter Unlock Code.
5. Re-enter Unlock Code.
6. Pantech C740 will display Unlock Process Complete. Press OK.
7. Your Pantech C740 is now unlocked.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the Pantech C740.
If you have any doubt in this, visit this Mobileunlockguide.com.This will provides the complete guidance for you.
Jul 25, 2011 | Cell Phones
Pantech c740 unlock code imei 011917001521014
Get the unlocking service from your network provider or you may get it from www.unlocking4u.com . After getting the code, you may follow the instructions here,
2. Type *#865625#.
If you have any doubt in this, visit this http://www.mobileunlockguide.com/pantech-c740 .This will provides the complete guidance for you.
Jul 25, 2011 | Pantech Matrix Cell Phone
NAD C740 Chanel B Speakers not working The speaker output A is working properly, then the output B is completely silent. I install differents speakers and even the same speakers. no sound from the B...
possibly the causes are: 1. defective channel B power amp board. But try operating first with the built in tuner, if it's ok the RCA cable from your other sources(DVD player, etc...) might have broken internal conductor.
2. if it has the speaker switch(A, B, A+B) try toggling it, might also just loose contacts.
if the trouble is #1, leave everything to your trusted qualified technician, he knows what to do, unless you want to tweak/repair it by yourself...hope this helps ;-)
Feb 03, 2011 | NAD C740 Receiver
How do i get my acer 4810T stared for the first time. I have charged it but will not start
This might be caused by a DoA (Dead on Arrival) unit ,a faulty launch board or a completely dead & faulty battery.
I would suggest removing the battery and try running the unit with A/C only and then pressing the power button to see if it boots up. Also make sure that your A/C is properly connected to power.
May 23, 2010 | Acer Computers & Internet
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
Turning off and on when driving
The only way to be completely sure that the problem does not exist in the power cabling is to run BRAND NEW power straight to the battery and/or ignition cct on the cars fuse block. This then ensures that you have solid power supply If you have checked the wiring and are completely confident that it is ok, then it is possible that the unit has dry solder joints. Power switching is done by devices mounted to the chassis of the unit and they often dry joint as a result of the heating and cooling cycle of operation. You could check this too by disassembling the unit and looking for failed solder joints and repair. Good Luck. :) Happy to chat more about it if you wish :)
Jan 15, 2008 | Pioneer DEH-P6800MP CD Player
Power light on, unit will not turn on with push button
When power was intermittant, were there any other discrepencies or audible power deprivation to the speakers? Your problem has many possibilites from fuses to major amplifier problems to common power supply failures. Being intermittant then dead may still be a simple fix, but not without some physical intervention of test gear. Sorry, Jaszy
May 30, 2007 | Onkyo TX-DS777
NAD C740 Receiver Logo
75 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
