Question about HP LaserJet 1000 Printer
HP 1000,STOPPED DEAD,THERE IS POWER ON THE POWER CORD,LEDS ARE OFF
Bought a new one
Posted on Dec 12, 2009
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
Everytime I start my machine, when it gets to windows, the screen goes dim and, I think, booting stops
what PC, all you posted is a screen.
we can not guess 36 years of PCs ever. sorry
my guess is PC is not HP, only the screen
this is near new screen
turn it on, and push the screens menu button.
see the OSD screen, now? sure, and that means the screen is ok.
and the PC is dead.
so post why is PC dead,get 100 reasons.
this position (ROOM LOC?) thing fools me, totally, sounds like bad cable.
or PC has loose parts.
if the PC fails with a borrowed monitor, is bet that makes sense ,, no?
The PC turns on,
the PC makes fan sounds
the PC dvd eject button works
the PC BIOS screens wall work
stop, i stop here we go father easy past BIOS working,
the BIOS hot key will not be the HP key cause yours is not HP
Jul 13, 2017 | HP 2311X 23 Widescreen LED Full Monitor -...
My HP Probook 4730s does not want to switch on. If I plug the power cord in the charging light flash blue ones and that is it.
ok all steps you did, are correct. sofar sogood'
all usb devices unplugged. all external things, but power cord.
did you do the HP long reset first? posted 1000000 times at the real HP forum..... we are not them.
battery out, line cord removed from PC (ac Pack)
hold power on for 10 to 30seconds. release
bingo for HP long reset, ok.
leave that old battery out (large) they can short. so....
line pack back, ac cord to wall and PC jack.
pack is 19vdc,read side of it, or if wise measure it.(volt meter)
new RTC coin cell. replaced, (tiny)
power on button pressed now, and the fan runs
if the fan is dead, this goal #1 the fan, always, next is text
if the fan is dead, there is no power or the fan is packed in lint
as most do after a year. we do the fan cleaning service next.
using AIR IN A CAN, BLOW THE exhaust ports clean and all vents.
you then tried a new power pack, and the fan is dead.
this pc uses LED backlamp screen, so need to test CCFL.tubes.
where are we, we are at no FAN ,no text
what's next, (gee get it repaired?) hah I sure you are here due to 1000 miles from nearest PC repair shop. so
what can you do, well lots with a screwdriver, got one?
if the AC pack is good, there are lots of magic things inside
to go bad, short and overload the POWER buses.
like bad ram
bad modem card, wifi card, bad blue tooth card.
HP real has service manual
all those up to 10 parts inside can in fact short.
we remove them 1 by 1 to find which one is shorted.
this is what all tech do. or go mad
Got beep codes, got LED FLASH CODES, TELL THEM NOW.
SEE BLACK SCREENS OF DEATHH HERE.
There are many forms of black screen,
text on the screen at any time is NOT blackscreen issues
see stripping here, (warning complex , done by trained techs)
see that not only power can short out, but so can data.,address or controls.(its Computer not a toaster)
http://www.pcdied.com/black-screen.html
now see the real HP,posted 1000s of times. your manual.
see service guide for how to take YOUR PC apart
https://support.hp.com/us-en/product/hp-probook-4730s-notebook-pc/5060893/manuals
Jan 27, 2018 | HP Computers & Internet
Power button shutting off as soon as i try to switch on
Shut down
Unplug the power supply.
Remove the battery.
Insert power cord
Reboot with power cord but no battery
If it comes up, your battery is dead or weak
Replace the battery.
If you don't even get a flash, your power supply may be bad.
Get a new power suppy.
If it continues the restart cycling, then there's something wrong elsewhere.
Jan 01, 2013 | HP Mini 1000 Netbook
My HP dv2000 shuts down and does not turn back on. The power cord is connected but the charging light is not on.
Your DC connector on the system board is loose:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
If it is under warranty, HP will repair it. If not , read this:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 30, 2010 | HP Pavilion dv2000t Notebook
HP mini wont turn on and power led blinking
Removed the battery - power it up from your a/c adapter then refit the battery -
Jun 26, 2010 | HP Computers & Internet
The PC doesn't start. led is not blue when power cord plugged
Below is a link to the service and maintenance guide. This will serve as a reference for disassembly. It is free to use, copy and print. It is in PDF format. I would check the voltage at the tip of the adapter to make sure it is putting out the proper voltage. I have seen plenty if failures with the HP laptops at the DC jack area, in most cases these jacks are connected to the motherboard by a cable and plug, which makes them easier to service than the soldered type. Here is your guide........
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01550099/c01550099.pdf
Jan 13, 2010 | HP Compaq 6830s Laptop
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
HP a820n No Power-up after City Power Failure
You have a bad power supply. It is not an expensive fix. Remember HP's take HP power supplies. When ordering either look on ebay for your model or order from part supplier.
Aug 22, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
I Need to locate the laptop reset button on it
to reset most labtops all you have to do is hold down the power button for about 15 seconds and it should reset
Mar 25, 2009 | Dell Inspiron 1000 Notebook
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
