Question about Microsoft Windows XP Home Edition
Have windows xp firewall corruption,
Unable to get winodws firewall to run even though, managed to repair firewall using the the using the netch firewall rest command and mount the cateloge. but am unable o get the firewall service to run when I enter firewall.cpl at the cmd I get service unable to run even though it has been repaird. Is there anything else I can do other than do a clean install of windows xp. This happend after installing of service pk 3, along with disabled usb, spooling problems with a printer and meda player problems. Have solved last three, but firewall causing an issue. Any suggestions would be appeciated.
    Brigadier General:
  • 10,406 Answers
Access "Add/Remove Programs", and uninstall Service Pack 3.
Posted on Dec 11, 2009
Unable to connect windows xp and windows 7 using crossover cable.
Your laptop ip address setting is correct now there is reason not able to ping windows xp and windows 7 have firewall you need to enable file sharing form windows firewall. Go to control penal > windows firewall > advanced settings > inbound rules and enable file and printer sharing.
Jun 15, 2012 | HEWLETT-PACKARD HP 630/P6200 Notebook
My vista is not performoing well .it dosent startup properly.only a black screen is comming.no msg is coming.it is only working in safemode.now i am in ubuntu
Resolution : Fallow method 1 or method 2 no data will be deleted.To resolve this issue, you must have the Windows XP CD-ROM. If you do not have the Windows XP CD-ROM available,
If you have the Windows XP CD-ROM, use one of the following methods. Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 A description of the Safe Mode Boot options in Windows XPIf you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.( In safe mode)
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
    For more information about how to use the Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base: 307654 How to install and use the Recovery console in Windows XPNote For more information about an error message that you may receive when you use the FIXMBR command, click the following article number to view the article in the Microsoft Knowledge Base: 266745 Error message when you run fixmbr commandWarning If your computer is infected with a virus and you use the FIXMBR command, you may be unable to start the computer. Before you use this command, make sure that the computer is not infected with a virus.
  4. If the primary boot partition is a FAT partition, use the FIXBOOT command from the Windows XP Recovery Console to write a new boot sector on the system partition, and then use the FIXMBR command to repair the master boot record.
Method 2: Repair your Windows installationNote Repairing your Windows installation may change the configuration of Windows. You may also have to follow this step if you complete all the troubleshooting in steps option 1 and the problem is not resolved.
  1. Use the Windows XP CD-ROM to start your computer. On the Welcome to Setup screen, press ENTER to set up Windows XP.
  2. Press F8 to agree to the license agreement.
  3. Use the ARROW keys to select the Windows XP installation that you want to repair, and then press R.
    Windows XP Setup repairs the installation files, Windows XP automatically restarts, and then the Setup program finishes the repair of your Windows XP installation.
  4. Follow the remaining steps to set up Windows.
    Note You must have your 25-character product key to complete these steps.
  5. As soon as this issue is resolved, make sure that the firewall is enabled, and then visit the following Microsoft Web site to reinstall the latest updates: http://windowsupdate.microsoft.com/
  6. Run a virus scan on the computer because problems with corrupted elements can be attributed to viruses.
Dec 26, 2010 | Computers & Internet
How do i get to windows xp from black screen
hi
  5. As soon as this issue is resolved, make sure that the firewall is enabled, and then visit the following Microsoft Web site to reinstall the latest updates: http://windowsupdate.microsoft.com/ (http://windowsupdate.microsoft.com/)
Jul 04, 2010 | Dell Inspiron 6000 Notebook
Repairing windows (wmi) on windows xp ser. pk. 3 not wanting to replace the os in the process.Restoring to an earlier date isn't working, says its unable to restore to that date.But, anyway finding that...
Microsoft has released a new diagnosis tool that helps system administrators diagnose and repair problems with the WMI. It is advisable to go through the WMIDiag_ReadMe.doc file to understand how the utility works, and the supported command-line arguments. Here is the download link: The WMI Diagnosis Utility
You may use the utility (WMIDiag.vbs) to find if a repository rebuild is necessary or not. The utility runs a comprehensive testing of WMI and reports the results to a log file, which is placed in the user's Temp folder (%Temp%) folder by default.
Mr. Alain Lissoir [MS] was kind enough to share the following info with me:
If there is a need among all problems detected by WMIDiag to rebuild the repository after attempting all fix suggested by WMIDiag, WMIDiag will list the rebuild of the repository as the last action among thing that can be done (before rebuilding the repository).
Here are some of the useful links that I came across from Alain's homepage:
Mar 24, 2010 | Microsoft Windows XP Professional With...
When using internet my pc hang
use WinsockFix will solve your problem, if you using Win XP click Here to download it.
Read this for Vista :
When Winsock corrupts, the networking errors that you may face include unable to surf the Internet with “Page cannot be displayed” error message in Internet Explorer or AOL even though the DSL/ADSL/cable Internet connection is connected. Sometimes, Windows Firewall/Internet Connection Sharing (ICS) service is terminated as well. To repair and reset the Windows Vista
  1. Click on Start button.
  2. Type Cmd in the Start Search text box.
  3. Press Ctrl-Shift-Enter keyboard shortcut to run Command Prompt as Administrator. Allow elevation request.
  4. Type netsh winsock reset in the Command Prompt shell, and then press the Enter key.
Source for vista : click Here
Dec 22, 2009 | Compaq Presario Notebook
Windows unable to locate cd drive
you reformat your hard disk and install guienuine microsoft window xp your problem will be fix
Oct 26, 2009 | Computers & Internet
Unable to ping my ISP gateway
This could be an issue having to do with the installed drivers for your network adapter. XP and Vista use different drivers, even though the hardware is the same...Take a look through this tutorial and make sure all your network hardware has vista drivers installed. Also possibly helpful would be a read through of this vista help site...
I would start there, and if you need further assistance after making sure you have the correct drivers for vista, write back and we'll be happy to help you sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 11, 2009 | Microsoft Windows Vista Home Premium with...
Unable to reach firewall periodically
If you are using the firewall as the DHCP server, you may need to check the DHCP lease period on the firewall & increase it if required.
Mar 24, 2009 | SonicWALL Pro 2040 Firewall
Firewall settings
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
Restart Windows, and then run this command (from Command Prompt):
Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
Apr 21, 2008 | Microsoft Windows XP Professional With...
Problems
WIn XP has a built in Firewall that may be enabled. To disable this Click on Start, go to control panel and then network connections. Right click the local area connection and go to properties. Click the advanced tab and uncheck: Protect my computer and network by limiting or preventing access to this computer from the Internet. If you do not do this it can prevent you from using the router or even accessing the router configuration screen. The reason it causes a problem is the router already has a firewall and the built in firewall can cause a problem.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Microsoft Windows XP Home Edition Logo
76 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
