Question about Creative Labs Zen Micro MP3 Player
Turning on when i try toturn my player on all that comes up is recovery mode.It says clean up, format all,reload firmware or reboot.... when i tey one of theoptions nothin happens.Why is it doin this how can i start again.. cheers
I have the same problem but i hope to fix it if i do then i will tell you how
Posted on Jan 21, 2008
What can i do if stuck with recovery mode ? i had done reboot , format , clean up and reload firmware but it doesnt worked at all . does it cannot be fix anymore ?
what can i do if stuck with recovery mode ? i had done reboot , format , clean up and reload firmware but it doesnt worked at all . does it cannot be fix anymore ?
Jul 08, 2012 | Creative Labs Zen Micro MP3 Player
Credit card size zen
Hi Lil
Sounds like you have tried all the obvious. The unit may have a terminal hardware problem or an unrecoverable firmware problem. I suggest that you return the unit to a dealer and see if there support guys can produce a cure for you. I am looking for any other things that you may try. Will post any for you soon
regards
Graeme
Feb 17, 2008 | Creative Labs Zen Digital Media Player
My brother's MP3 player is messed up. When you boot it, it automatically goes to recovery mode. Here, it tells you the firmware and gives me a couple options: Recovery Mode Creative Zen Micro...
Couple things to try.
Let the battery drain completely, then do a full charge and try again.
When turning it on, don't hold the ON slide, just slide it to ON then let it go. Holding it will send it into recovery and reset mode.
Jan 25, 2011 | Creative Labs Zen Micro MP3 Player
Recovery
reload firmware is your best choice
Jun 21, 2009 | Creative Labs Zen Micro MP3 Player
Turning on
I actually had this exact problem a little while ago with my Zen Sleek-- Booting straight to the Recovery menu, and only getting a generic "Harddisk problem" error screen any time I would try to do anything.
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
good luck
please mark the post with a fixya
Feb 20, 2008 | Creative Labs ZEN SLEEK MP3 Player
Problem with 'Hardisk Problem'
"Hard-disk Problem"... I'd just like to confirm once more that smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I didn't try smacking it till I checked out the threads above so thanks everyone I'm a happy man again!! :)
or
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Jan 19, 2008 | Creative Labs Zen Touch MP3 Player
Recovery Mode
Clean Up
Format (All)
Reload OS/ Firmware
Dec 28, 2007 | Creative Labs ZEN V Plus MP3 Player
Frozen MP3 Player
There's a reset hole by the side of the player. Try reseting it. It can freeze sometimes, and fix itself after a while. no apparent reason. reset, run the battery down and recharge. Hope it helps. this is from the creative site: The recovery mode consists of these four operations. * Clean Up: It is the least destructive operation. It scans a player's hard disk and removes any invalid links from the music library. It does not affect music files themselves. It is recommended that you perform "Clean Up" first before formatting or reloading the player's firmware. It is recommended that you clean up regularly if you frequently transfer files between a PC and your player. * Format All: It is the same as a Windows format performed in a PC, and consequently all contents will be lost after a format. * Reload Firmware: Reloads the player's firmware (Operating System). It will also format the player. Note : It requires the player be connected to a PC that meets the player's minimum system requirement. Select this option ONLY if you have access to a PC and you have downloaded the necessary firmware to install. * Reboot: Reboots the player. You can reboot the player after performing a clean-up or format, or reboot it without performing neither of them. It is recommended that you try these operations in the following sequence: reboot the player; clean up and reboot; format and reboot; and finally, reload the player's firmware. If your player seems to stuck in the recovery (rescue) mode, you can try the "reboot" operation first, and format the player if necessary. If it fails to reboot, you will need to connect the player to a PC, and reinstall its firmware. For a detailed instructions on how to install a player's firmware, please refer to Updating the firmware on a Creative MP3 player, or refer to the Web Release note of the firmware download. Unlike other hard disk based players, Zen Neeon does not have a rescue mode. Though there is a Player Recovery Mode , it is for use when updating its firmware only. 1. Detach your player from your PC , and ensure that it is turned off. 2. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications. 3. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe. 4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen. 5. Hold down the Play/Pause button while connecting the player to a PC's USB port. 6. When the Creative logo appears on its screen, release the Play/Pause button. The player is now in Player Recovery Mode.
May 19, 2006 | Creative Labs Zen Neeon MP3 Player
Creative Labs Zen Micro MP3 Player Logo
21 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
