Question about Sanyo DS31520 31" TV
Why is my tv flickering - Sanyo DS31520 31" TV
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
SOURCE:
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Need fixs how do i make it stop flickering?
How do i stop my vizio from flickering? - YouTube
? 2:18
https://www.youtube.com/watch?v=RD2PwPFpbrE
Jul 19, 2013 - Uploaded by colguon38
Please help me stop my TV from flickering. ... 1080p. the monitor will momentarily change resolutions. that is the "flicker" you see. unfortunately i ...
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY ... I have this exact make and model. .... and theflickering didn't stop. any ideas as to which JP I should cut . please help not ready to buy a new TV.
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
this might work for other tv's too. ... If your not sure you can dothis repair your self please take it to a tv repair shop. The repairshould be ...
Jan 04, 2016 | Televison & Video
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
PS3 Flickers on and off on the screen
Is could be your TV and not the PS3. When the resolution of the screen changes, you TV will flicker to adjust to the new resolution. My TV flickers in a similar way when playing games of lower resolution than my HDTV.
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Jan 09, 2008 | Sony KP-46S25 TV
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Flickering Picture?
Your set might have a high voltage leak and that is the noise you hear when is showing the screen problem or even maybe an arking too ,either one is related to the high voltage and it can be dangerous,if you are familiar with tv service you can try to see where is arking and replace the part with an exact replacement but if the set has a leak you will not see it and is not safe to be close to it,if you are not too familiar be safe and call for assistance from a servicer.
Oct 27, 2006 | RCA F35731MB 35" TV
Flickering
When you say flickers?? does the sound stay on or does the whole set go on then off or is it just the picture that flickers on and off and sound does flicker too? need more info please.
May 06, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sanyo DS31520 31" TV Logo
189 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
