Question about Brother HL 4200CN Laser Printer
We installed a new fuser into a Brother HL4200CN (Fuser FP-12CL) and it came up with "ID Error for Fuser" Is this a defective fuser or were we suppose to reset a code somehow? Thanks
  • 11,800 Answers
This message appears when the printer cannot recognize the fuser - probably because you haven't reseted the counter. Make sure it's properly installed. If it is then you will need to perform the reset procedure
1. Press Additional Functions Key
2. Press # key
3. Arrow to number 7, Printer and press Set
4. Arrow to number 4, Printer Re-Set and press Set.
5. Press Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
Posted on Jan 27, 2011
How do i fix the error code 6000 in kyocera 3060?
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
Dec 19, 2015 | Kyocera Office Equipment & Supplies
How can I fix the printer if it indicating room high temperature
8 - low fuser temperature (subthermistor) 9 - high fuser temperature (subthermistor) This error usually indicates a defective fuser. Turn off printer for 20 minutes ...
Aug 20, 2013 | Brother Office Equipment & Supplies
Error E04-01 Panasonic DP-4510
E4- 01
Fuser Warm-up Temperature
Possible Cause(s)
1. Fuser Thermistor dirty.
2. Thermistor position incorrect.
3. Thermistor defective.
4. Thermistor connector disconnected.
5. Fuser Lamp connector disconnected.
6. Fuser Lamp defective.
7. Fuser Thermostat defective.
8. Thermal Fuse defective.
9. SPC PCB connector disconnected.
10. SPC PCB defective.
11. Fuser temperature low. (Adjust F6-31)
12. Incorrect SC PCB is installed.
13. Incorrect SPC PCB is installed.
Aug 05, 2011 | Panasonic FP-D355DC Copier
Error fuser unit hl-5350Dn
The fuser unit is located at the rear side of the printer.
Fuser unit error indicates one/more of the following.
1. The fuser roller/film life is over. Replace with new one
2. The fuser film is torn. Replace with new one.
3. Fuser heater is burnt. Replace the heater.
4. Fuser thermal sensor is open. Replace it.
sonsunny
Jun 28, 2011 | Brother HL 5250DN Laser Printer
Panasonic FP-D250 copier first displays error U16 - install the developer unit - then changes to machine error E04-01. Any suggestons?
hello robertsona from robertsand. e4-01 is fuser warm up. check connections and fuser thermal fuses, as well as the lamps. good luck
Jan 25, 2010 | Panasonic FP-D250F Copier
Brother MFC-9700 Machine Error 71
71 says the fuser unit is not installed, it means the fuser lamp is burned out, or the temp. sensors are bad. In either case the best repair is a new fuser which you'll find at www.precisionroller.com
Jan 18, 2010 | Brother MFC 9700 All-In-One Laser Printer
Replaced fuser unit on HP 4350dtn and now get a 50.5 error.
The 50.5 error indicates "wrong fuser installed" on a 4350DTN printer the correct fuser is RM1-1082, it will not work with RM1-0101 even if the 0101 fits the printer. Remove the fuser and look for a small label giving the part number and check it. If you need to get a fuser let me know, we have them in stock.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jul 23, 2009 | Office Equipment & Supplies
Fuser melting the roller and "fail to warm up" error
you could will hae a defective thermistor. Check it out
Jun 01, 2009 | Brother IntelliFax-2820 Laser Fax
Machine error 77
the fuser unit (fixing unit) not registering heat requirement. The heat roller or the thermistor sensor is defective.Remove fuser and check roller, if good replace sensor, reinstall fuser and reset machine.
Aug 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Panasonic FP-D355 Error Code E04-01
the best thing that u do first is to clean the fuser unit, esp. the thermostat located there. then you may go to service mode, (function+orig.size+3), F9, look for ram initialize, then look for LBP FUSER RESET.
it will reset all e4 machine error.
Jan 16, 2008 | Panasonic Workio DP-3530 Copier
Brother HL 4200CN Laser Printer Logo
344 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
