Question about Black & Decker Irons
My new black & decker steam advantage iron won't glide over clothes, it's almost like it wants to stick to the clothes.
  • 96 Answers
Check the instruction manual and see if it says to clean the surface before using it , if not try cleaning it and use it on something old in case it wants to scorch the fabric
Posted on Dec 13, 2009
Just plugged in brand new iron and the variable steam dial won't move
please take it back, it will only give you more problems. irons are not made as well as they use to be.
Jan 24, 2015 | Black and Decker USA Applica Black &...
How do I clean a not self clean ,quick press s506a , not self cleaning black and decker steam iron
Most steam irons can be cleaned deposits by emptying the water and replacing with white vinegar. Let it heat up and use the iron as normal - but on cloth rags instead of clothing. The vinegar breaks down and dissolves the mineral deposits inside that are responsible for sputtering and stains. You can reduce or even eliminate these deposits from forming by using distilled water instead of tap water in the iron - otherwise - run vinegar thru it when it starts acting up. The vinegar "trick" works great on coffee makers, too.
Dec 03, 2014 | Applica Black And Decker Steam Advantage...
How to fix a Black and Decker Iron?
irons are not meant to be fixed due to their construction. the cost is generally more than a new one ( if you could get the parts)
take it to an appliance service centre to determine exactly what is the fault but be prepared for a "new one" answer.
May 08, 2014 | Applica Black And Decker Steam Advantage...
The steam wheel on black and decker digital advantage is stuck in the no steam position
This problem developed with our iron within the last week. Playing around with it today, I discovered that the dial WOULD respond to "persuasion". I forced it, and it cooperated. Find somebody with a stronger grip and try it.
Aug 03, 2013 | Black & Decker D2020 Iron
Hi, I have a Black & Decker digital Evolution iron. It has worked fine in the past but now when I turn it on to any temp setting it starts flashing #8 and beeping. I have never seen the #8 on it...
Try this cleaning procedure:
Empty the iron's reservoir.
Fill the reservoir halfway with white vinegar.
Set iron to steam setting.
Steam on a cotton rag allowing the vinegar to clean the holes in the soleplate.
If this cannot be performed, or does not work,
at Black & Decker's normal price point, it is simply easier to dispose and purchase new.
Best regards,
Feb 25, 2018 | Black & Decker AS675 Iron
Instructions for steam clean on B&D iron
http://useandcaremanuals.com/pdf/D1200,D1500,D1600,D1650997.pdf
Or http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Hope this helps you.
Aug 01, 2010 | Black & Decker Irons
How do I clean my iron? The iron part on outside
Here is a tip that will help you with cleaning the bottom of your iron...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 05, 2010 | Black & Decker Steam Xpress AS250 Iron...
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
Irons Logo
203 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
