Question about Indesit 23 in. DV62 IX Built-in Dishwasher
DOOR TENSION The door is too "savage" the tension need adjusting but how there are no obvious screw's available or do we have to remove the dishwasher from its fixed position to get at screws on the side that is if they are there?
  • johnms Feb 20, 2008
    The apparently unsolvable is solved and so easily Thank you for your answer it has made life a lot easier for us BRILLIA NT
  • chrisroast May 29, 2008
    I've loosed the tension adjustment as far as it will go and it still shuts too fast and will not stay open by itself.
Open the dishwasher and look at the top of the chassis, where the door catch is. You'll see 2 screws with hexagonal heads, one on either side of the catch. Turning these screws will apply or reduce tension on a wire liked to a spring on either side of the door. Tension must be equal on both sides.
Posted on Feb 18, 2008
How do I fix or replace the door spring in a Miele G6892 dishwasher?
Step 1: Get Access to the Door Spring Remove the lower panel under the door. Normally, two screws keep the panel in place. These screws are located on top of or below the panel. There are cases wherein you have to initially open the dishwasher door to be able to remove the screws. The door should then be closed in order to remove the panel.
Step 2: Remove Springs To remove the springs, the hook of the spring should be lifted from the anchor point. Use your fingers to do so. If there is a large amount of tension, it's best to use a screwdriver or pliars. Position the shaft under the hook and then pull it down. After pulling down, try lifting the anchor. To make things easier, try locating a leverage point. This should help the screwdriver force the spring out. Be certain to remove the spring from all of its anchor points.
Step 3: Installation of New Springs To install a new spring, you initially have to deal with the positioning of the lower spring hook. It should be placed within the first hole. Take note of the adjustment bracket when doing this. Follow the previous set up. If the spring needs more tension, try positioning the spring hook further towards the back of the adjustment bracket. The end of the spring for the counter balance of the door should be mounted on the door support. Find the slot on the support. Replace all covers and door panels. Test the door to check for any problems.
Jul 16, 2016 | Miele Dishwashers
How do I adjust the door hinge tension on a Beko Dishwasher DW51
Hello!
most dishwashers have springs on each side of the door bottom that can be moved to different mount points to adjust tension.
In many cases they may be accessed by removing the bottom kick panel, but it may be necessary to back off the from adjuster legs, remove any other cabinet securing screws and pull the unit out slightly.
All the best.
Nov 20, 2014 | Beko Dishwashers
My dishwasher door will not stay up unless locked. I have installed new springs, to no avail
Might help with solution if you provide make and model number of dishwasher.
Sometimes the solution is a simple as ensuring the dishwasher is level so that the door shuts. The spring tension may need adjustment and usually there are a few screws at the top of dishwasher panel. Depends on make and model.
Jan 05, 2013 | Dishwashers
HOW TO ADJUST TENSION ON DOOR
Just below dish loading door you will see a panel. Remove screws (if applicable) to remove panel and you will find the door tension adjustment. Turn adjustment usually with a screw driver to the left to loosen or opposite lifting door opened and closed till you are happy with tension.
Jan 31, 2011 | LG LDF6920ST Stainless Steel 24 in....
ADJUST TENSION DOOR
Just below dish loading door there is a panel. Remove screws (if applicable) to find tension adjustment. Turn screw to the left to loosen or opposite lifting door open or closed untill happy with tension. Some washers have no adjustment, I suggest opening door fully and pulling out bottom load tray, loading and then top tray or rack, pushing top in first then bottom rack. Use a glass fry pan cover or fry pan for weight on door while filling soap. Good luck, best regards
Jan 31, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
Door spring seems to have broken
Yep! What happens is a "T" shaped metal piece that is "screwed" into the spring and serves as an adjustment of tension tears or bends and falls out of the spring(s). Usually one at a time.
If you are clever you can rebend and strengthen this piece and adjust the tension to normal.
Access this by removing the panel below the door where the toe kick is.
The cause of the problem will be obvious and one side will probably still be intact so you can see how they are supposed to be.
May 02, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door does not stay horizontal when opened. How do I adjust the door springs?
Hello Slosh,
The are four torx screws (Two on each side) of the door panel near the bottom. The top screw controls tension and the bottom allows you to position the door. Be careful when loosening the panel as the screws will come out completely and then you will need to remove the outer door panel and reattach the door springs
Sep 15, 2009 | Miele 24 in. G638 Plus Free-standing...
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
501 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
