Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Freezer drain line keeps freezing over
I have a Whirlpool refrigerator (approximately 6 years old) in which the freezer drain line freezes over regularly. This results in moisture draining through the overflow holes and into the refrigerator below. If I thaw out the drain, it will freeze closed within a day. I have shut off the ice maker supply line in hopes that this would cut down on a possible source of water, but the drain still freezes over. Any suggestions on what is causing the drain line to freeze and how to prevent this?
    President:
  • 1,218 Answers
Good day,
Whirpool machines have a very short defrost cycle, as compaired to many brands. This definitely contributes to the problem.
1. Make sure the drain fittings and drain hose to the drain pan are completely open. Not just open, but blown free of any debrise.
2. My experience with many whirlpool products, is ice built up under and back of the drain pan in the freezer compartment. It cannot be seen.
To solve this problem long term, means unplugging the machine, defrosting, and drying it out completely.
24 hours and idealy with a floor fan blowing into the compartment.
3. As well, you wil notice a small round disk clipped to the top of the evaporator. This is the defrost thermostat, and controls the temperature during defrost.
I change and bump this tstat up 5 degrees.
For example, if it's a 50 degree tstat, I replace it with a 55 degree. Or if it's 55 degrees I use a 60 degree model.
You will not be able to buy this as a Whirlpool item, but you can with a little effort, use a GE kit.
The part number for GE replacement kits are for example "WR50X55", the last 2 numbers are the temperature of that tstat, and run in 5 degree increments from 45 degrees to 60 degrees.
A sharp appliance parts house counterman should be able to help you.
P.S. The tstat in Whirlpools are often given in Celsius.
You'll have to convert that to farenheit
Patience in drying the machine is your friend here.
Jack..
Posted on Dec 11, 2009
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator water condensation drain line freezing
GO TO THE FREEZER PORTION OF THE FRIG.YOU NEED TO TAKE THE ICEMAKER OUT AND REMOVE THE BACK PANEL WHERE THE EVAPORATER FAN IS .RIGHT UNDER THE COIL YOU WILL SEE A DRAIN ,WHEN YOUR FREEZER GOES ON DEFROST THE WATER GOES DOWN THE DRAIN AND INTO A PAN THAT SITS ON TOP OF THE COMPRESSOR.THE HEAT FROM THE COMPRESSOR EVAPORATES THE WATER.THE DRAIN IN THE FREEZER IS PROBABLY CLOGGED OR FROZEN OVER WITH ICE AND THATS WHY THE WATER IS GOING ELSEWARE.REMOVE ALL THE ICE FROM AROUND THE DRAIN.IF THERES A ROD THAT GOES DOWN THE DRAIN FROM THE DEFROST ELEMENT THATS SUPPOSED TO KEEP THE DRAIN FROM ICING UP ,IN ANY CASE THE DRAIN IS CLOGGED OR ICED UP.UNCLOG THE GRAIN AND YOU WILL BE GOOD TO GO.
Mar 20, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Kenmore 106.71299100,water freezes on floor of freezer,drain line freezes,I have opened drain with hot water etc.then problem returns in about one month. the refrigerater is 6 years old and this problem is...
You have a partially plugged drain, causing water to flow too slowly. Try reaming out the drain with a long stiff wire until water flows thru it like a faucet. You may have to unplug the unit for a day to get every part warm enough. Hope this helps!
Jan 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Defrost drain is freezing up
That drain in bottom of freezer need to be perfectly clean with no debris around. Then you have to thoroughly clean and snake out the drain line that goes down to the tray for the evaporation of the condensate. If it goes into fridge and there is another drain there same procedure must be done.
Sep 06, 2017 | Jenn-Air JCD2297KE Side by Side...
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Nov 30, 2008 | Refrigerators
Kenmore 71192100 frost free keeps freezing up
Hi. thanks for the question . The first thing i would do is clear the drain tube .that could be why the freezer ices up .too much moisture Clean the drain, And the coils at the back. thanks the appliance doc
Sep 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
909 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
