Question about RCA RS2028 CD Shelf System
How do you open the cd tray on a RCA RS 2028 - RCA RS2028 CD Shelf System
  • 715 Answers
Look for small hole on the c d tray put a small toothpici or large needle in hole and push .tray should open
Posted on Dec 11, 2009
Rca rs2650 tray wont open and cd wont play
Remove the CD tray the drive motor and gear is joined by a belt. I used a matching rubber band it works. Most of these drive motors. have a belt for safety. Important to replace the CD tray at the same location for line-up with your CD player drive. If you can get couple manufacturer belts do so. The belt is little tougher than the rubber band. And clean all your moving parts gently .
Dec 27, 2013 | RCA RS2650 Shelf System
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
I have a rca rs 2663 stereo, The cd tray will not open or play cd's anymore. Could you please help
It two things can cause this:-
The motor is damaged ( you can listed closely to hear if the door motor runs when you try to open the tray.
Or The belt that takes power from motor to open mechanism is damaged.
Aug 19, 2011 | RCA RS2663 Shelf System
My rca rs 2764 system the cd player wont open
Hi, what makes a CD player not ejecting or not opening is because the Sim tray which carries the CD inside the player when inserted is damaged and it's not performing it suppose to. o weak to function, You will need to replace the Sim tray that allows the CD go in and out...
Have a nice day...
Feb 18, 2011 | RCA Audio Players & Recorders
Rs 1286 rack system,cd tray not working properly,player wont read or play disc (made by rca)
If the radio and cassette work, then your CD lens needs to be cleaned. You can buy a cleaner CD, or you can do a better job by removing the case (MAKE SURE THE POWER IS OFF) and then clean the lens with a Q-Tip and denatured alcohol.
Feb 18, 2011 | RCA RS1286 CD Shelf System
My rca rs 1289 5- cd changer mini system will not play, open, close, or change cds. how can i fix this problem at home?
Remove the case screws on the left and right side panels. Pay attention to the long screws that come out of the middle of the panels to make sure they get back in the right spot. Remove one screw from the top rear back panel. Lift side panels of in a hinged motion from the bottom. Remove the top panel in a hinged motion from the rear. In the center of the disc tray remove 1 screw from center. Note the orientation of the tray for re-insertion. Lift the tray up and out. look for small dc motor and spindle. this motor is used to spin the tray. You should find a black belt2_bing.gif between motor and spindle. Make sure it is in good condition. Look to the right rear of the unit. there is a second motor and belt which drives the tray. This belt may be broken or off its spindle. repair or replace the belt as necessary. Plug the unit in and test the open/close function and ensure the gear train, belts2_bing.gif and carriage move smoothly. reassemble.
Apr 11, 2010 | RCA RS1289 5-Cd Changer Mini Systemwith...
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
CD trays will not open.
Use a paper clip. If you push a wire in the holes of each tray it will release the trays. The proper holes look like little dashes on the face of each tray, one end or the other.
Feb 11, 2009 | RCA CDRW121 2-Disc CD Recorder
RCA RS2028 CD Shelf System Logo
222 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
