Question about Envision Computers & Internet
I have an envision LM-700 monitor and I think the blub blew out today. WHich one do I need and how do I replace it?
  • russelc Dec 12, 2009
    I think it is the bulb because I can still see the desktop very faintly on the black screen. Also I know a little something about monitor repair (although it was CRT monitor repair including soldering on a new fly back (I don't know if you know what that is --- you may be to young) and swapping out a whole monitor chasis. I understand that swapping out a bulb on these new LCD's is an in depth project, but my monitor is over three years old and has had constant usage, so I would expect the bulb to die on me right about now. Now depending on the type of bulb my monitor takes either I will have to solder it on after desoldering off the old one, or there may just be connections. I wont know until I know what bulb I need. SO again, I have a Envision LM-700 monitor - do you know what bulb it takes?? Thanks -
  • 732 Answers
Russelc, Before you even start to replace a "bulb" inside your unit I suggest that a visit to www.ccl-la.com/badcaps.htm and www.lcdparts.com to get a handle on just what is involved with a DIY project like this. WHAT even makes you think a bulb blew OUT??? There are many other components inside your monitor that can cause your BLACK SCREEN symptom. Did you visit YOUTUBE to view video clips of "LCD monitor disassembly" and/or "LCD monitor repair"??? It's not like changing out a failed "new style" screw-in curlie-Q CFL lightbulb that you can get at the local home depot or menards!!! Get back to me after you understand the two or three major causes of LCD BLACK SCREEN symptoms and how others have repaired their units.Also tell us how old or approximate total "ON" hours of use unit has. Did it have a bright, colorful, crisp text and graphics just prior to the BLACK screen problem?? Does the unit have a BLACK BRICK lay on floor power supply or is unit connected directly to wall outlet or surge protected power strip??? Let us know what your going to do after you do some research on the web. Also read some of my (and others) responses to other BLACK SCREEN LCD owners to see if different approach is needed. Bye for now. 12fixlouie aka louie12fix on fixya
Posted on Dec 11, 2009
  • Louis Ebert Dec 13, 2009
    russelc,I worked for Tv manufacturer that was bought by LG. And Yes!! I know what a flyback is and have measured and taken data on the HOT's that drive them. The CCFL's you need can be bought online. You will need to know the length and also lead length. Try www.ccfldirect.com I still think you have a SMPS/INVERTER problem. Good luck though. 12fixlouie
I need a driver for my G2016 monitor
We have no software here for download.
Jul 28, 2017 | Computers & Internet
My laptop LCD screen is FUBAR and in order to use my computer I have hooked it up to an Envision 19" LCD Monitor. If I start Windows Vista in Normal mode , it does not recognize the Monitor. Pressing...
I would go ahead and boot into safe mode where you say it does work and then take a look. See how it detected it...ie look in device manager and see if it picked it up by it's true brand/type etc. Check the settings both of the display and on the envision itself. Check the resolution selection. It's probably picking it up as a lower res. but when it boots into reg windows may be trying to run at full res and perhaps that's what it won't do. Check to see what driver it's using. It may need the specific driver from envision and not the generic driver. It could also be a bad pin on the envision itself.
If you have another computer you can hook it up to, do that to make sure the envision is working. That way you can deduce which is the problem, the monitor or the setup in your laptop.
Jul 10, 2011 | Envision 19" Widescreen Flat Panel LCD...
I have an Envision LM-700 and the ac adaptor is no longer working. where do i get a replacement
Hi cintiman32,
If you wish to get the replacement of your Envision LM-700 AC Adapter click this LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 25, 2011 | Envision EN-7100e 17" Flat Panel LCD...
Speakers
the speaker cable goes into the green 1/4 inch pin jack on the tower the pink is for microphone and, blue is line the monitor should have the same markings
Jun 01, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Envision EN8500 inverter
no you cant change it yourself because there need some tehnical knowlege so better you buy new one
Dec 09, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision LCD
That mean your logic board of the LCD need repaired or replaced.
Apr 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
H 170 L-17" monitor
If *nothing* displays on your screen, the most likely problem is your LCD Backlight Power inverter. If the backlight power inverter is bad, you can usually see some remnants of an image on the screen if you shine a light on it. If the backlight power inverter is bad, it may not be worth repairing on a 17" screen, considering the low cost for a new one.
It should be noted that Envision provides a 3-yr warranty for most LCDs, so contacting them for repair may be a good option. More information here:
http://www.envisiondisplay.com/support.asp?EPage=support&SMenu=lcdwarranty
Feb 17, 2008 | Envision H170L Monitor
Computers & Internet Logo
708 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
