Question about Canon PowerShot SX20 IS Digital Camera
Anytime there is movement in the area I am shooting, the image comes out blurry. I do not know how to fix it. Still images are great, but, like I said, as soon as someone moves or walks their image is blurry. Any advice?
  • 667 Answers
Try setting the flash to always on. Even Pro shooters use flash in daylight.
Posted on Dec 11, 2009
Photos are coming out blurry
There could be several reasons for this - pick the most likely !
If the entire image is blurry, with no sharp detail, it could be camera shake, or subject movement, especially at longer focal lengths (i.e. at the telephoto end of the zoom range). Try using a tripod or other firm support and see if that improves things.
If only parts of the image are blurry (i. e. the background is sharp but closer objects are not) then the autofocus system could be selecting the wrong area upon which to focus - try using lock focus on the subject, then re-compose.
The front element of protective filter could need cleaning - carefully!
The camera could have suffered a knock which has dislodged one or more of the internal lens elements - in which case, a visit to the repair centre is called for.
May 17, 2016 | Olympus Cameras
One side of picture not in focus
Hello ehutson !!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed hope it will fix the issue
Regards
Smilemaker.
Jun 18, 2008 | Canon PowerShot S2 IS Digital Camera
I have a ViviCam X014N. Everytime I take a close up pictures, the images comes up fuzzy. What am I doing wrong? I follow Macro setting recommending 30-45 cm away, but still no luch.
Sounds like you're not using a tripod. Macro pictures have a very small area that can be in focus....the slightest movement can cause the blurry pics.
Sep 19, 2011 | Vivitar X014 Digital Camera
Does not focus after "far" objects when zoomed to 50mm or more ...
  1. If your images suddenly start looking blurry or distorted, try holding your camera up to the light. If your lens looks dirty, foggy or greasy, try applying lens solution with a lint-free cloth . Move the cloth in a circular motion until the lens dries. Do not apply lens-cleaning solution directly to the lens.
  2. If your images are still blurry, check your shooting mode. If you are shooting closeups, make sure you are using the "closeup" mode. Try to get within 2 feet of your subject before you shoot the picture. images can look more blurry when you are a long way from your subject
hope this helps you please do me rate on this issue
Dec 23, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
My images are blurry
check that you have not left it on close up settings ! micro
Jul 14, 2009 | Casio EXILIM Digital Camera
Fuzzy images
Hey jjbeanwink,
This is a very nice lens, and is unlikely that your blurry images are caused by the lens. The most common cause of blurry pictures is that the shutter speed is set to low. A general rule would be your shutter speed should be at least 1/60th of a second while handholding the camera. The bigger the lens, and the higher the magnification of the subject you are using the faster the shutter speed you should use. If camera shake is the cause of your blurry pictures you could also try using a tripod. Another common cause of blurry images is subject movement, and one solution would also be setting a faster shutter speed. Another solution is using the flash to stop the action instead of the shutter speed. Of course manufacturers do occasionally make a bad product and that is why there are manufacturers’ warranties. If you just purchased this lens you could have an authorized service technician look at the lens and see if there is anything wrong with it. I these suggestions help!
Sincerely,
Allan
Go Ahead. Use Us.
May 12, 2008 | Canon 24-70mm f/2.8 Lens
Image qulaity problem in fujifilm finepix fd50
It sounds like the resolution on the monitor may be set incorrectly in Photoshop. Try a different monitor setting. Twelve megapixels may result in your monitor "seeing" so many pixels it tries to ignore the excess ones, resulting in an image that looks poor on your monitor. If you order one print, that may give you an idea of the true printed quality without spending a lot of money on a bunch of bad prints. The F50 is truly an excellent camera and gives super images, from my experience.
Mar 02, 2008 | Cameras
I have a Casio EX 260, not the EX-S600
Try resetting camera. If that doesn't work more than likely there is a lens error. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 07, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
SONYA CYBERSHOT DSC-S600
sounds like someone has changed the shutter speed. Look in owners manual on how to change back to default. might also look at the picture type settings but setting the camera for action shots u will get better images if there is movement in the image.
Dec 27, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Canon PowerShot SX20 IS Digital Camera Logo
120 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
