Question about Executone Lands Phones
Can you tell me how to change the time? I know to hit the program button, but can't find the commands to change the time and get out of programming. Our system is from 1995 and I have only been here for two years and the guy that did this before is no longer here. I cant find the administrators guide.
    Problem Solver:
  • 20 Answers
On what kind of a thingy???
Posted on Jan 06, 2018
5 Suggested Answers
SOURCE: Administrative program manual
I found manuals for the Vodavi products at http://www.wedophones.com/Manuals/Vodavi
Posted on Feb 13, 2009
SOURCE: Setting Time on Lucent Partner 34D cuase error
you have to use this method from the main phone on your system
Posted on Mar 19, 2009
cnavarro
  • 2460 Answers
SOURCE: Program Date and Time
From the phone at extension 10 or 11 press FEATURE 00 Left Intercom Left Intercom #103 and enter the 4 digit military time. (if you need it, the date is #101 in mmddyy format).
Press FEATURE to exit
Carl
Posted on Mar 20, 2009
  • 13 Answers
SOURCE: Toshiba dkt 2010-sd
Try going to the following website: Toshcom.com and click the System/Phone Manuals tab Or click the following link http://www.toshcom.com/TManuals
Posted on Mar 16, 2010
Why is my IIIWoods 50013 outdoor 24 hour timer switching to OFF regardless of setting? How do I fix it?
First start with the reset button, clears out all past commands.
First the clock has to be set to the proper day and time, It might be in the 24 system versus AM and PM you can find this out by stepping through all the hours when the time comes on. To set clock press Set and see what is flashing, if it is the day, scroll to the right day and hit set, now time should flash scroll to right hour, press set, right minutes, press set, right seconds, press set; Now the clock should be set.
Next you do the programs you want again go through same process, hit program 1 should flash press set, now the days should flash, scroll through till you have the right combo of days, one day, all days of week, Sat, Sun, then last the whole week will flash, if that is the one you want then press set, now press set and the times should flash for hour.
pick the time you want to come on, hit set for hour, minute, second, then hit set again now hit the program button again and it should say off, go through the same steps and set hour, minute second then hit set for last time. In a few minutes it should change to reading the time on the screen. Then you have to wait and see if it works. To do a mini version, see if it will work get a lamp plug in set all the above but use a very short on off time like 4 or 5 mins, then you will know if it is going to work right. then set for the correct time. good luck hope it helps. If it all messes up just hit reset and start all over, REMEMBER it can't so anything until the time of day is set right that's the starting point.
Dec 04, 2016 | Hardware & Accessories
Need to change video display in Autocad running in DOS
Hit the "Alt" and "Enter" keys at the same time while in the full screen window. This will change the full screen to a window.
Right click the blue bar at the top of the window. Choose "Properties." Click on the "Options" tab. Make sure the setting is on "Window" rather than "Full Screen."
Click "OK." When you are prompted with save options, choose "Save Properties for Future Windows with Same Title."
Change the properties for the general command prompt. Click the "Start" button. Click "Programs" and "Accessories." Right click the "Command Prompt" icon.
Navigate to "Properties." Choose the "Options" tab. Check the button next to "Window" instead of "Full Screen." Click "Apply," then "OK."
Use the mouse to right click on a DOS program's shortcut. Choose "Properties." Select "Options." Under "Display Options," select "Window." Click "Apply" and "OK."
Open the command prompt or your DOS shortcut. Right click on the blue bar. Click "Properties" and go to the "Layout" tab. Under "Window Size," use the arrows to increase the height and width of the window. Click "OK," click "Modify Shortcut That Started This Window" and click "OK."
Custom Car Parts
Jun 06, 2012 | Autodesk Computers & Internet
Good afternoon, I search a french instructions for Micro Pets tomy "Gork " Serie 2 U.S . I have forget my instructions list :/ Please help me. Thank you
If you have a brand-new MicroPet, remove the"Try Me" plastic strip before using the pet.Turn the MicroPet over and locate the plastic strip protruding from the batterycover; pull the strip straight out.
    • 2
Change the batteriesif the power is running low -- the included batteries are used for testing andmay not be fully charged. Turn the MicroPet over and use a Phillips-headscrewdriver to remove the screw at the top of the battery cover. Slide thebattery cover out and remove the old batteries. Insert two LR44 batteries,making sure to match the polarity as instructed. Replace the battery cover andtighten the screw with the screwdriver.
    • 3
Wake up your MicroPet by pressing the button onits head; it will perform an action to let you know it is awake. Say a phraseto your MicroPet, then wait for its nose or tie to light up. Now say a secondphrase and the MicroPet will follow your command. For example, say,"Robo," then wait for the pet's nose to light up, then say,"Run," and the MicroPet will run.
    • 4
MicroPets display two "moods,""happy" and "bad," depending on the commands it receives.If you repeat the same command over and over, your MicroPet will display a"bad" mood. It will then refuse to listen to your commands and willnot respond to you. Praise yourpetto cheer it up and make it happy. For example, say, "Good job," toyour MicroPet.
    • 5
Press the button on top of the pet's head while itis performing a command to reset the MicroPet.
    • 6
Hold down the button on the top of your MicroPet'shead for three seconds to make it go to sleep; it will sing a goodbye songbefore shutting down.
    • 7
Make your MicroPet sing one of three songs byclapping your hands. Clap three times for "It's a Small World," fourtimes for "Ten Little Indians" and five times for "ElectricalParade." Make sure to wait for the pet's nose to light up between eachclap. Place multiple MicroPets together and they will sing in unison.
    • 8
To program your MicroPet, turn the MicroPet off,then press the button on top of its head six times --- the pet will light up,then make three small beeping noises. Wait one second and the pet will light up--- press the pet's head button now if you want to program the "GoForward" command. To program the "Turn Right" command, wait forthe pet to light up twice, then press the head button. To program the"Turn Left" command, wait for the pet to light up three times, thenpress the head button. When you hear three beeping sounds, the MicroPet isfinished programming and will perform the commands. You can program up to fivecommands in a row. When in program mode, your pet will not respond to your voicecommands or sing songs. To go back to the normal command mode, simply turn theMicroPet off then back on.
Feb 18, 2011 | Tomy Micropets Tomy - Kuda. Magic voice...
How do I delete program times for the filter pump on the Aqualink rs8 panel?
These are great systems: Go into "MENU" (MENU BUTTON) Scroll down until you see "MENU/HELP" Scroll down to "PROGRAMS" - HIT "SELECT" when you find "PROGRAMS" It will say "PROGRAM 1 of 1" that is what you want - Hit enter - This will tell you what time the program is set to run
If there is more than one program, You will see "PROGRAM 1 of 2" or however many programs you have programmed.
If you need to delete a program, go to the program you are looking to delete, it will ask you if you wish to delete the program and you will use the up and down arrow on the panel.
It is really that simpe!
For deletion of all programs (factory default). There is a SMALL reset button. The lights will go out and then light up. Will light up to the left and then to the right. Resetting this will erase all run times back to factory default. You will not loose your programs (memory of knowing what system it is) it just resets the times to factory default (1200 Military times). ***IF YOU HAVE A COMPLICATED PLUMBING SYSTEM WITH SEVERAL RUN TIMES - DO NOT DO THIS!**
If you are looking to just erase additional run times and only need the one run time (for circulation) this might be the better option to resetting and erase all run times and reset back to a basic 1 of 1 run time.
Dec 07, 2010 | Jandy Pool & Spa
Change the number of rings when the voicemail picks up
You will have to go through the programing button. You know the one you hit and it tells you the time the dat and how many rings etc. re program it for the max rings it will allow usually only 4 but maybe yours will do 7 Not sure, If you have the manual it will tell you. You should always keep manuals to everything you but, just throw them into a bag somewhere at leastyou'll have them when you need them I usually keep a pair of reading glasses in the bag too. Good Luck !!
Feb 09, 2009 | Uniden Cordless Phone
In visual basic how will we change the backcolor of the form randomly when we click the command button?
Paste this code on you button. This generates a random color.
Red = Int(Rnd * 255)
Green = Int(Rnd * 255)
Blue = Int(Rnd * 255)
Form1.BackColor = RGB(Red, Green, Blue)
Oct 06, 2008 | Computers & Internet
Locate % button
There is no % button on the calculator, but depending on what you need it for, there are some simple basic programs that could work for this. If you just want to find percent from a fraction or decimal, use this one.
Hit the program button and press right two times the enter to get a new program.
Name your program "PERCENT"
hit enter
hit program, right, enter, to paste "Input" onto your screen
In quotes, put "Number?", then a comma, then N (not in quotes)
Press enter to get to a new line.
Enter "100N-->N" (once again, not in quotes)
The arrow is found directly above the on button
Press ENter again, putting you on the third line.
Hit program, right, 3 to paste Disp on your screen.
Put N after, not in quotes
Your screen should look like this:
PROGRAM:PERCENT
:Input "NUMBER",N
:100N-->N
:Disp N
Press 2nd Mode to quit, then hit the program key and select program Percent to run (making sure you are in the "Exec" menu)
Hit enter to run your program: it should turn decimals or fractions to percents.
Don't feel that your intelligence is being insulted by me giving explicit instructions that may be below your level in programming: I did not know whether or not you were proficient.
Apr 24, 2008 | Texas Instruments TI-84 Plus Calculator
Changing Time
Hey peoples this worked for me :)
On the main phone
- hit the "PROGRAM" key
- then key in **
- it asks for a password key in 1234
- then key "NEXT"
- then key "ENTER" (this is to set the date)
- then key "NEXT" (this is too set the time)
- once the time is correct hit the "ENTER" key at the bottom of the phone.
Mar 09, 2008 | Panasonic KX-T7630 Corded Phone
Cannot find code number for programming remote control. the brand of tv is DURABRAND. THANKS
Try this site: http://www.remotecodelist.com/remotes/
You'll need the remote you're trying to program, then follow it to a link that will give you the codes for what you're attempting to program it too..
Bill
Feb 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Lands Phones Logo
29 people viewed this question
Top Executone Lands Phones Experts
Marvin
Marvin
Cabanaboyz
Cabanaboyz
Level 1 Expert
Tom Chichester
Are you an Executone Lands Phone Expert? Answer questions, earn points and help others
