Question about Brother Office Equipment & Supplies
Brother dc gear motors features
Please help me about three DC gear motor which are remove from Brother 5500 copier machine. Only informations on their box are: brother DC 598701, brother DC 598702, brother 598703. I need information about their voltage , current, rpm, conection, etc.
  • 87 Answers
SOURCE: Mita DC-1205 Copier
If you need a manual for it try looking on line for older copiers. Since that unit was built back in the mid 80s.The other person that helped you on the toner is exactly right.
Posted on Oct 24, 2007
  • 3 Answers
SOURCE: xerox dc 12 copier system faulit 9-354
yellow toner not feeding
Posted on Aug 14, 2008
  • 155 Answers
SOURCE: xerox DC 3535 error 116-332
Simultaneously press and hold the 1,the Stop
and the Power Save buttons on the Control
Panel,if problem continues repeat the same
with
6,the Stop and the Power Save buttons
4,the Stop and the Power Save buttons
3,the Stop and the Power Save buttons
Posted on Aug 28, 2009
  • 257 Answers
SOURCE: my mita dc 1260 copier has failed to get into simulation mode
Some of the keys on the panel are worn out. Check c and ready keys and replace .
Posted on Dec 01, 2009
  • 10 Answers
SOURCE: MITA DC 1460 copier stops
try switching to "manual" exposure setting instead of "auto" call service to check sensor and process control
Posted on Jan 06, 2010
HI I M KAMRAN I HAVE CLJ5550N PRINTER ERROR ARE COME 59.30 I REPLACE TRANSFER KIT BUT ERROR STILL 59.30
Hello ,pls check as describe,
Reconnect the connectors J18 for
the fuser motor and J1101 on the
DC controller PCB. Replace any
damaged parts.
2 Replace the fuser drive assembly.
3 Replace the DC controller PCB.
Calibrate the printer after replacing
the DC controller.
Mar 22, 2011 | HP Color LaserJet 5500 Printer
Tip
ERROR codes Canon 6230
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6035
Canon 6035 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controller
57 service
57 (or 57.1) SERVICE Message (Main Motor Failure)
The 57 SERVICE indicates that the DC Controller PCA detected a
general motor failure. The Main Motor drives all moving
components in the printing process. The Main Motor is a 4-phase,
DC servo motor controlled by the DC Controller PCA.
The formatter detects a Main Motor failure when:
• The Main Motor does not come up to speed within one second
of receiving drive voltage.
• The Main Motor deviates from the correct speed for one second
after reaching the correct speed.
Main Motor Functional Checks
• Inspect the gear train for debris that would block the free
operation of the gears.
• Check the gears in the Toner Cartridge for wear and binding.
• Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
the DC Controller PCA, and the main connector on the Main
Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
Controller PCA connector locations.
• If the problem persists, check that the +24B Voltage is present
on the DC Controller. If the voltage is not present, replace the
DC Controller. If the voltage is present, and the motor does
not rotate, replace the Main Motor Assembly (see Figure 7-11
for location).
Oct 21, 2010 | HP LaserJet 4 plus Printer
Brother AX-25 typewriter won't print
If the cams assembly in the carrier unit does not cycle properly the power on routing will not complete. This problem can be caused by worn contacts in the dc motor, causing intermittent or slow operation of the cams during POR or printing. This is common with older machines. I have replaced quite a few dc motors in carrier units of this style of printer. The motors are no longer available but they may be revived by spraying a good electronic cleaner in the holes of the motor to clean the brushes (RH SIDE). Take care to not damage the plastics of the case with cleaners. If you have many machines w/ motors, you may become accomplished at disassembling the motors and repairing the brushes, but this is difficult and time consuming.
Nov 16, 2009 | Brother Office Equipment & Supplies
Error code 000051
From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES: a. The horizontal registration assembly is out of place because of
damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the
presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the
sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty. Replace the motor.
NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
395 Service Engine Error
Hello kieran,
This might help you. I found this on one printer forum.
From the manual:
Fuser Drive and Contact Cam System Service Check
Error Code 993: Indicates the cam sensor has not been activated.
The sensor activates when the fuser drive motor turns the cam disk.
If the fuser drive motor does not turn on, or the drive parts are not
operating, go to A.
If the fuser drive motor turns and appears to be operating properly,
and the cam is turning, go to B.
and the cam is not turning, go to C.
A The fuser drive system is not operating properly.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
Check the fuser assembly internal drive gears
for binding, or broken or worn teeth. If a
problem exists, repair or replace the fuser
assembly.
Remove the fuser drive motor from the stay
assembly, leaving the motor cable connected
to the motor. Turn the printer on, but do not
allow the motor to touch other areas of the
printer. Verify the motor turns during POR. If it
does, the problem is most likely in the motor
mounting stay assembly. Go to step 2.
Check the motor for shorts between the case
and each motor winding. If a short is found,
replace the motor.
Note: Damage to the engine board may result
from a shorted motor.
Check the motor for open windings. If found,
replace the motor.
Check continuity of the fuser motor/paper feed
motor/carriage unit motor cable.
• If incorrect, replace the cable.
• If correct, replace the engine board.
2 Motor Mounting Stay
Assembly
(Fuser Drive Parts)
Check the fuser drive gears, gears C3-1, C3-
2, the clutch spring, motor drive gear, gear C2
and C4 for signs of chipped gear teeth, worn
parts, or improper operation. If problems are
found, repair as necessary.
Check the cam gears and solenoid for proper
operation and signs of broken or worn gear
teeth or damaged parts. If found, repair or
replace the motor mounting stay assembly.
B The fuser drive system is operating properly and the cam disk is
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
Be sure the cam sensor is mounted correctly
and locked into place.
Check the following voltages on the cam
sensor:
Pin # Signal Voltage Voltage
Voltage Disc in Disc Out
1 (Orange) +5 V dc +5 V dc +5 V dc
2 (Brown) -CCSENS +5 V dc 0 V dc
3 (Green) GND 0 V dc 0 V dc
Note: The voltage on pin 2 should vary, as the
cam turns from approximately 0 V to +5 V dc.
• If the voltage on Pin 1 is incorrect, check
the cable. If incorrect, replace the cable.
• If the cable is good, replace the following
FRU's in the order shown:
1.Cam sensor
2.Engine board
3.SN cable
C The fuser drive system is operating properly and the cam disk is
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
Check the solenoid for proper operation,
making sure it picks during POR cycle.
Disconnect the solenoid and check the
resistance on the solenoid cable. It should
measure approximately 65 ohms. If incorrect,
replace the solenoid.
Check the voltages on the solenoid cable
connector.
Check the following voltages on the contact
cam solenoid cable connector:
Voltage Static Picked
1 (Red) +24 V dc +24 V dc +24 V dc
2 (Black) -SL2ON +24 V dc 0 V - +24 V dc
Note: All voltages are approximate.
continuity of the CRF cable to the cam
solenoid.
Assembly
Check the clutch spring, clutch boss, clutch
disk and gear C4 for signs of wear, broken
teeth or binds. Repair or replace the motor
mounting stay assembly if a problem is found.
Normaly the fuser is not turning - check the cleaner pad is not jammed in too tight. Then replace the fuser drive block 12G1348.
Jul 29, 2009 | Lexmark C510 Laser Printer
Error message 993, what is this?
that is a fuser drive error on printers. it is the part that fixes the ink to the paper.
i have a check for you but is not an easy fix.
if fuser drive is gone will cost approx £12 to replace.
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio GX3050N Printer
HP LASERJET 4 PRINTER
Failure)
Nov 06, 2008 | HP LaserJet 4 plus Printer
Error code E 000025-0001
 hello i m ramy,first  replace the toner bottle, second check the hopper motor connection,
 hopper motor unit gears.
or test if there 24 vdc .to the motor
Mar 27, 2008 | Canon imageRUNNER 5570 Copier
114 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
