Question about Maytag 24 in. MDBH950AW Built-in Dishwasher
Dishwasher fills up with water and then does not run
I have a portable LG dishwasher.I did not use it for about a month and then when i Tried to use it all it will do is to fill up with water and then nothing happens.I can see the power is on and timer is tell me what is the problem? Can I fix it by myself?If not how much it will approximate cost me to get it fixed?
    Top Expert:
  • Maytag Master
  • 49,126 Answers
Fixya not being an actual repair shop has no idea what might be wrong since we can not test the unit , nor do we know what a local shop might charge for it
Posted on Oct 20, 2017
  • 878 Answers
SOURCE: portable dishwasher
The first thing you might want to do is check the water pressure in the house. Ideal water pressure should be from 55psi to 75psi max. I have seen homes that had pressure around 125 psi which will cause pressure leaks in water heaters, softners, washer valves, r/o systems. Check to see that all, if any inlet screens are clear and free from any grit and sand. It's possible that your inlet water valve (wd10m0010) has become restricted. Other than that, the complete uncoupler hose assy. part number is wd24m0030. These parts are for the dishwasher model ending in gsc3400j00bb. They are the same for model number ending in 00ww. Good luck.
Posted on May 07, 2006
  • 1314 Answers
SOURCE: Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Posted on Dec 31, 2007
  • 9 Answers
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
All kinds of qwerks with newer Kenmore units. When did u buy it?
Posted on Jan 26, 2008
SOURCE: GE Nautilus dishwasher wont run
getting ready to try what everyone suggests......wish me luck
Posted on Nov 11, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
My Bosch dishwasher is taking hours (at least 3 - maybe more) to complete a cycle. There is gummy, yucky stuff building up inside - sorta pinkish brownish. Could the water not be hot enough? A couple of...
if your on demand heater is one of the small ones that mounts under the sink, it will not flow enough water to fill your dishwasher. the dishwasher is waiting for the water level to fill before it starts washing. your bosch will heat its own water. hook it up to a cold line ahead of the water heater so that the fill valve is fed with full pressure. the residue sounds like detergent build up. when you get the water issue resolved, run a few cycles with no dishes and no detergent, on the highest temp setting. add a cup or two of white vinegar or dishwasher cleaner ( order online or get from an appliance repair store) through it. Dont forget your dishwasher has a filter in the bottom under the spray arm that needs to be cleaned periodically. if you dont clean it once a month it will get all kinds of nasty stuff built up in there.
Nov 20, 2010 | Bosch SHX46A07UC Built-in Dishwasher
Lg dishwasher never heats water
The LG 7811 dishwasher is supposed to even support a cold water (vs. hot water) connection. Then it will heat the water up to 120 degrees upon each fill cycle. This is not optimal and it adds much time to the already long full cycle. When you run the hot water at the kitchen sink until it is hot and then kick off the cycle, is the water hot at the beginning? It should be 120 degrees minimum and well under 140 degrees maximum.
Do you get any error codes on the display? Troubleshooting is possible, but recommend you contact LG service at the number in the user guide asap. Press for fast, free resolution to this problem. Please reply when you have gotten this fixed, explaining what fixed this nice, quiet dishwasher. Good Luck!
PS: When you get it running, do not use ultra-cheap dishwasher soap. Recommend Electrosol powder or cascade. Never use gel or tablets on this water conserving dishwasher.
Feb 02, 2009 | LG 24 in. LDF 7811 Stainless Steel...
LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Dec 31, 2008 | LG LDF6810ST Stainless Steel Built-in...
GE Portable Dishwasher won't fill/cycle
In a front corner of the tub is a float switch that raises up as the machine fills, then shuts the water off. when pumping water out the float drops and enables the fill solenoid valve to work when signaled by the timer circuit. Make sure the float is free to rise and fall. The residual soap may be holding the float up. Run some cycles without soap to clean the tub, manually clean it out if necessary. Make sure the water supplied to the machine is at least 129 degrees to get good cleaning and prevent soap build-up.
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
LG Dishwasher
Had a similiar problem I tried reducing water pressure from water inlet (external to dishwasher) and this worked to a certain degree, although may result in being unable to fill, if you turn down too far. Water silencer (try plumbing stores) was fitted between mains and dishwasher and this fixed the problem.<!-- from fixya rte -->
May 16, 2008 | Dishwashers
Dec 31, 2007 | Dishwashers
LG dishwasher
Does it a brand new dishwasher ?
Sep 03, 2007 | LG 24 in. LDF 7811 Stainless Steel...
Maytag 24 in. MDBH950AW Built-in Dishwasher Logo
130 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
